Tyre Pressures
Posted: Tue Dec 14, 2004 8:09 pm
I got a set of alloys with 195/55/15 rubber on them, what are the correct tyre pressures for these.
Probably the Worlds greatest Polo resource
https://uk-polos.net/
Gulp - sure you've got 195/55 15?Musicfreek2002 wrote:I got a set of alloys with 195/55/15 rubber on them, what are the correct tyre pressures for these.
Carefull "carma" bearing in mind tyre pressures change with profile - i was gonna jump in with that but the tyre size made me think twicecarmadaaron wrote:2.1 bar all round
Exactly what i was thinking - the higher the sidewall the greater the pressure needed to keep it stiffSpeedlaw wrote:Nahnah, that's way off. You need 45's, or 50's if your cheap. 55's will cause problems when lowered and look horrible.
I run 2.6 or higher, I add a little to compensate for high loads and high speeds.
