Page 1 of 3
Timing belt noise?
Posted: Mon Dec 27, 2004 11:12 pm
by metz
a rather large screeching sound is coming from inside the plastic cover that houses the timing belt, Gareth (gt hatch) has changed the belt and water pump about 1k ago so i would have thought they wouldn't need changing...any ideas guys?
Its there at tickover (loud) and gets faster as you press the throttle.
Posted: Tue Dec 28, 2004 12:35 am
by Gareth_GT_Hatch
Im fairly certain its the timing belt "bedding-in." We had a big discussion about this on the mk2 forum a couple of months back. GC and tahrey had the same problem. You could try slackening the tension a bit (which is what GC did) but imo its as it should be, tahrey said it takes a fair few miles to go away though. Its probably more like 2 or 3 hundred miles since I changed it rather than 1k (it was only about 2 or 3 weeks before i dropped the 1.4 in when I changed it all) You should have heard the noise the old belt and pump made!
I guess you got it running today then?
Posted: Tue Dec 28, 2004 8:58 am
by metz
cheers gareth...
Yea started it boxing day and finished it (with the help of 2 squabbling brothers) yesterday.
Peter n Andy you were a big help...and entertaining at times
If its just bedding in i'm less worried now as i was worried about it snapping it was that loud.
It wasn't very quick at first either, but after matts dad had realized we set the accelerator cable wrong i had full acceleration again and its pretty rapid now
Posted: Tue Dec 28, 2004 9:02 am
by Josh_PoloGTi
I'm going to need to watch in my mirror for a speeding saloon now!!
Posted: Tue Dec 28, 2004 9:10 am
by metz
I will sneak up behind you when your unawhere and eating....Then while your braking i may be able to get past lol.
When the whinings gone i will nip over to lapland (looks like it with bloody snow) and give you a test drive.
Posted: Tue Dec 28, 2004 12:00 pm
by ste mk1lx
not meaning to step on any toes but is the belt tensioned correctly mine squeeled when the new belt was just slightly over tight
Posted: Tue Dec 28, 2004 3:11 pm
by Gareth_GT_Hatch
It is tensioned correctly. Its a black art though "can be turned through 90 degress half way between the cam and crank pulley" is the specified level of tightness. and the level of tightness that the belt is at does fit within this specification. Although like I said you could probably loosen it a bit just to see if the noise goes away.
must be good going from 45 to 75bhp!
congrats on completeing the conversion so quickly. did you run into any problems with wiring?
Posted: Tue Dec 28, 2004 5:46 pm
by Young_Un
glad its all ok, wat was up with the accelerator cable??
thought sumthin must ave been wrong wen i was backing off, otherwise my super powerful gt would have rammed you, mwohahahahha
squabbling brothers, dunno wat ur on about
Posted: Tue Dec 28, 2004 8:20 pm
by metz
the cam belt was slackened off slightly and the noise has all but gone now (only ever so slightly there when the engine is hot)
Young_Un seems the cable wasn't adjusted right for the gt TB as the pedal only moved an inch and i wasn't getting full revs. Minor thing though and its sorted now
So bring on the GT for a rematch
Topped the tank up 2nite so i hope your petrol pipe work is sound yoof
Targets obliterated so far include :- 1.6 mondeo *2 up full of shopping*....1.4 6n *2 up* 1.4 #corsa *1up* ( # sorry for the language)
1. summat 306 *1up* and he was very shocked to see a polo saloon 3 up sailing past him on the duel carriageway, he even went for another go a bit later on..i let him pass then sat on his bumper until i decided i had won
If i haven't killed myself i will be at a show near you soon.
Posted: Tue Dec 28, 2004 8:56 pm
by Young_Un
heh, bring it on!
stock vs stock (and nitrous... mwohahahahha)
Posted: Tue Dec 28, 2004 9:01 pm
by metz
mmmm....yoof presses switch yoof goes fast...engine melts ..metz waves as he goes by
Posted: Tue Dec 28, 2004 10:26 pm
by GroovyCarrot
That 90° thing is something to be very wary of
Mine could be turned 90° when it was whining like crazy.. it can now still be turned 90°, just more easily
Haynes really should make it clear that the belt should turn 90° comfortably, rather than with a bit of effort.
Posted: Tue Dec 28, 2004 11:01 pm
by metz
mine can now be turned 90o still but its a little easier..it does require a little effort from finger and thumb still though. (can't find the little o lol)
Posted: Tue Dec 28, 2004 11:03 pm
by Gareth_GT_Hatch
Good news all round then!
Glad my GT engine has gone to a good home. See you at the rr day?
Posted: Wed Dec 29, 2004 3:04 am
by Tahrey1043
sweet! (and me not on the msn at the mo hehe)
after 1000 miles i'd be getting worried about the belt so good thing you loosened it a bit - i think mine needed a few hundred rather than a few thousdand, a month or so of doing a 12 mile round trip to the hotel on irregular days for work..
do miss that vacuum clearer whizz, great for scaring small kids and making sheetroen drivers think i had a turbo
does this mean i can have your gearbox and induction kit now metz?
