Bee Sting Aerial...
Posted: Sat May 31, 2003 8:09 pm
by ciden
How easy is it to remove the bee sting aerial? Are there screws involved or does is simply 'turn' off? The reason why I'm asking is, I was browsing the website of the new sedan, and noticed a very interesting aerial fitted to it. It's like a combo between a fin and bee sting aerial. I don't know if it's the one fitted to cars that has the SAT/NAV option, anyways I'm including a pic.
(Sorry about the small size)
Posted: Sat May 31, 2003 9:10 pm
by Petrified
Yeah, I think it's part of the SAT NAV.
In my experience you usually have to get at these things from underneath
Although I may be wrong.
There are some better pictures of it somewhere, I'll try to find...
But on a brighter note, I have now de-locked my car
James.
Posted: Sun Jun 01, 2003 11:03 am
by Nelson_Wilbury
Yeah, that ariel is Sat Nav only.
The ariel itself is actually bolted underneath the headling and its very hard to remove it without causing some sort of creasing/damage and apparently you never get the factory finish back
Much better than the bee-sting ariel is the new Shark-fin one now standard on the Touran. I might buy one in the future but I don't know whether to risk the headlining
Posted: Sun Jun 01, 2003 11:38 am
by polo2k
removing an aierial is easy and ive done it on my polo a few times
all you need to do is drop the headlining enough to get your hand behind it which can usually be done by unclipping the side trims suporting it and then i might just flop down and then you can usually see the base which should have a cable going to it which you should remoce if there are aparebnt fixings and then usually a 10mm or 13mm nut to remove and pull it off
as for the creaces they can be caused by forcing the headlining (can be cured by cheating a humid atmosphere in the car with a kettle and then pulling against the crease) or if your tlking about in the metal then its due to over tightening and/or using the wrong washers
Posted: Sun Jun 01, 2003 11:46 am
by Nelson_Wilbury
Damn! Ignore me
I now know why the headlining creased on the car I was looking at. Perhaps because it was a Bora (and hence not a hatchback)
Ignore me
Posted: Sun Jun 01, 2003 1:15 pm
by ciden
Uhmmm ok...u lot scared me now - I'll be keeping my bee string aerial
I couldn't handle damaging my baby!
Jacob
Posted: Mon Jun 02, 2003 11:32 am
by des_pd_ tdi
Don't worry about replacing the aerial, I needed a new aerial that supported my DAB stereo, the replacement aerial is a bosch one, has a slightly wider base similar to the original and has a painted black finish.
I have had no problems with the headlining, everything clips back into position - no rattles.
Des
