Hello, just looking for some info on a strange brake feeling.
When braking I can feel in the pedal a sensation like the car is braking uneven. From what I have read it could be a warped disc?
The backstory is in mid Nov the car was serviced/Mot at an Indy VW near me. New front discs and pads were fitted as low and they mentioned the back would need doing in the near future. All has been good till about a week ago when I started getting this weird sensation.
It is often difficult to get booked in quickly at the Indy so I got my local garage to check the brakes. They called to say that I was lucky I brought the car in as I had 2 studs missing and 2 loose in the Offside front with only the locking nut tight. On the front nearside 2 of the studs were loose.
They looked at the brakes and said they were fine but the back could do with pads but not desperate. I got pads fitted and drove away relieved.
I can however still feel the braking sensation although it is more subdued. It is very evident at slow speeds when coming to a stop. The car drives perfect and no vibration anywhere, just this weird sensation when braking that I can feel through the pedal.
What do you think?
The front discs are defective?
The back discs need replacing?
Something has gone wrong due to studs missing?
Why did the garage not notice this on road test I wonder?
Thanks for reading and any advice/suggestions
Weird brake feeling
Re: Weird brake feeling
check the ball joint for play, and rear wishbone bushing
- Drives: 1.2 TSI Match
Hi amer6R
Wouldn't they affect the car when driving all the time though?
It's only under breaking that I feel it. Especially at low speeds when you are nearly at a stop its most noticeable. The only feeling or vibration or pulsing is through the pedal.
From what I am reading I am guessing it's the discs. Gonna take to the garage again tomorrow. Is it easy to see if the discs are warped? Or is it only by driving that you can tell?
Could it be a sticking caliper? Garage say it will need to go on a rolling road to diagnose it
New discs and pads needed. Warped, Only 3 months since they were done!
- J+silva
- Drives: polo conf.
It happened to me in December 2023, I changed the rims and tires of my polo, everything was calibrated and the steering was aligned, in February of this year the car only trembles when braking after 60/70km, I changed pads and discs, all new, in April now it started shaking again braking, from 60/70km onwards, below that speed it doesn't seem to shake, I don't know what could be
