Myślę, że jest to wystarczająco zrozumiałe przy użyciu tłumacza google.
The first time I write in Polish. (sorry if it is not correct)
- Drives: Seat Ibiza 6j1
After all, as a student of the master, I still don't understand what you are talking about
Good Polish language, you could be a PL / EN translator
It's really simple:
WRM = Window Regulator Motor. (door units managed by BCM)
SW = Software.
- Your WRMs don't have the proper SW.
- Forget the "rain closing" function, and the "automatic folding mirrors" function with remote/key fob.
Your WRMs: (Red = software)
Podsystem 2 - Oznaczenie elementu SW: 6R0 959 801 AK HW: 6R0 959 801 AK Plik etykiet: 6R0-959-801.CLB
Komponent: J386__TSG_FT 007 5110
Numer seryjny: --------------------
Kodowanie: 020000
Podsystem 3 - Oznaczenie elementu SW: 6R0 959 802 AR HW: 6R0 959 802 AR Plik etykiet: 6R0-959-802.CLB
Komponent: J387__TSG_BT 007 5110
Kodowanie: 020000
The SW must be 8612 or higher.
The topic of Ibiza died by a bungler electrician ... Cyclo not everything works as it should and I do not know what the problem is, parking lights go out, not drl
- received_403652234567902.jpeg (35.87 KiB) Viewed 1795 times
- received_303822191368513.jpeg (41.48 KiB) Viewed 1795 times
Please show us an Autoscan as indicated. Thanks.ciclo wrote: ↑Wed Sep 01, 2021 3:22 amread my quote again ⬆ciclo wrote: ↑Tue Aug 31, 2021 7:49 pm Warning:
I will do the new BCM coding based on the Autoscan with the original BCM 087, which seems more reasonable to me than the Autocan with 7H0 BCM (with some inappropriate changes).
Later you can modify what you think is convenient, but remember that the one I provide should be your starting point for the BCM Max 7H0.
My recommendation is that you do not touch the new BCM coding that I provide you during the installation process (as if you were a magician's apprentice ), otherwise, we will not be able to know what is happening in case of faults.
7C8829F88861010001200EF06EEB9EC85FC067FF608D30C1200000030000
That is, the next autoscan must be with all new wires installed and with this BCM coding. Good luck!
It almost looks like your parking light T10 light is connected to the PWM signal, since it's very dim with parking lights and full brightness with DRL.
Cyclo tomorrow an electrician will do / send me a car scan, it will be pasted immediately when I get it
no errors in the autoscan, why does it have to be reverse and rear fog under bcm control?
Tomorrow I will throw in autoscan, but apparently no errors, any idea how to solve the problem with the DRL / parking lot?
ciclo wrote: ↑Tue Nov 09, 2021 5:32 pmPlease show us an Autoscan as indicated. Thanks.ciclo wrote: ↑Wed Sep 01, 2021 3:22 amread my quote again ⬆ciclo wrote: ↑Tue Aug 31, 2021 7:49 pm Warning:
VIN: VSSZZZ6JZDR026882 License Plate:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 4B 56 77
VIN: VSSZZZ6JZDR026882 Mileage: 164820km-102414miles
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 110224DB216F00B8882D24EA84D300401100
Shop #: WSC 00200 935 12345
VCID: 004CA1859702F18941-8054
Part No SW: 6J0 820 043 D HW: 6J0 820 043 D
Component: Climatronic H08 0707
Revision: S0000000
VCID: 2502D0112CE0F4A112-8070
1 Fault Found:
00457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 248
Mileage: 164828 km
Time Indication: 0
Date: 2016.04.01
Time: 21:30:45
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 HW: 7H0 937 090
Component: BCM PQ25 Max4 H72 0708
Revision: B9072001 Serial number: 0531 063131236
Coding: 7C8829F8C861010001200EF07EA80EC8F0C042FF608D2040200000000000
Shop #: WSC 95400 259 24646
VCID: 6B96E6298A8402D184-803E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 120315 05 54 0403
Coding: 07302D
Subsystem 2 - Part No SW: 6R0 959 801 AK HW: 6R0 959 801 AK Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 5110
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 802 AR HW: 6R0 959 802 AR Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 5110
Coding: 020000
1 Fault Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 248
Mileage: 164828 km
Time Indication: 0
Date: 2016.04.01
Time: 21:30:47
Component: VW10AirbagA01 H10 0020
Revision: -------- Serial number: 003GX016A6B0
Coding: 003031
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4AD843ADEDBEFBD9DF-801E
Serial number: 3495RRB406316Q1G31E
Serial number: 3505RRB405117HSIJ13A
Part No SW: 6J0 920 804 K HW: 6J0 920 804 K
Component: KOMBI H03 0507
Coding: 110A00
Shop #: WSC 12345 123 01234
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 32283B4D652E931987-8066
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H72 0708
Revision: B9072001
Coding: 422000
VCID: 70ACF145A3A2E109B1-8024
Address 25: Immobilizer
Cannot be reached
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 6J0 035 342 E HW: 6J0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7662260740
Coding: 020000
Shop #: WSC 64564 324 38760
VCID: 2600D71D51E6FFB91B-8072
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11211
Shop #: WSC 06402
VCID: 2F2E3239EA1CBEF1E8-807A
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441 A
Component: MF-Modul 0007 0001
Coding: 0000002
Shop #: WSC 77005 000 00000
VCID: 312A3441A828A801FE-8064
Address 56: Radio (J503) Labels:. 6J0-035-153.clb
Part No SW: 6J1 035 153 G HW: 6J1 035 153 G
Component: Radio H15 0204
Revision: R0000000 Serial number: SEZAZ2M4042195
Coding: 0001040002
Shop #: WSC 04941 000 00000
VCID: 291ADC2140F8D0C136-807C
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007662181617
Coding: 0E00000001010110
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_UHVNA A01015
ROD: UHVNA.rod
VCID: 3522005194408421A2-8060
3 Faults Found:
13635840 - Supply voltage
U1011 00 [000] - Voltage too Low
[Klemme 30: unterer Grenzwert unterschritten]
Intermittent - Not Confirmed - Tested Since Memory Clear
0022 - Radio
U1066 00 [000] - No Communication
[Steuergerät Radio (RNS): kein Signal/Kommunikation]
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [000] - -
OLD CODING
Address 01: Engine
Cannot be reached
Revision: --------
Revision: S0000000
Coding: 7C8829F88861010001200EF06EEB9EC85FC067FE698D30C1200000030000
Coding: 07302D
Coding: 020000
Coding: 020000
Coding: 003031
Coding: 110A00
Revision: B9072001
Coding: 422000
Component: IMMO H03 0507
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A98E32D8D7E1BD9FF-803E
Coding: 020000
Coding: 11211
Shop #: WSC 06402
Coding: 0000002
Coding: 0001040002
ROD: UHVNA.rod
3 Faults Found:
0022 - Radio
U1400 00 [000] - -
End----------(Elapsed Time: 01:29, VBatt start/end: 13.8V/13.9V)-----------
Cyclo your new coding :/
It is because of how the BCM Max works, and because it is the original way, contemplated in diagrams, of a proper installation.
Otherwise, errors in diagnostic readings would be generated.
It is possible, it will be necessary to try with other BCM codings.
I will take a look.
ciclo wrote: ↑Tue Nov 09, 2021 8:03 pmIt is because of how the BCM Max works, and because it is the original way, contemplated in diagrams, of a proper installation.
Currently, the rear lights are not under the control of the bcm because the electrician says that they work properly and since there are no errors, you do not have to do it like this
False, that is not the BCM coding that I provided you, my BCM coding here viewtopic.php?p=585587#p585587
I said it was better not to touch the coding ... I don't know why I was ignored in this regard.
It does not matter, I am very used to the fact that due to multiple circumstances people say things incorrectly ... nothing to worry about!
To find out what's going on with your DRLs and side/parking lights, try these new BCM codings:
1-
7C8829F88861010001200EF06EEB9EC85FC067FF608D20C1200000030000
2-
7C8829F88861010001200EF06EEB9EC85FC067FF608C20C1200000030000
and tell us the results to know what is the next step to take.
Regarding the reversing light and rear fog light:
Some diagnostics were already disabled in your BCM coding, which may be the reason why the Autoscan does not show any faults, but I would like to remind you that diagnostic failures arise when those lights are activated.
If there are no faults in your instrument cluster, or in the diagnosis, and you are happy that way, leave it as original, but you may lose the diagnosis of said lamps in case the bulbs fail.
Work properly: When everything works correctly.
The diagrams you asked me through PM.
Diagram for 6P left halogen headlight.
There must be different models due to the information provided in the diagram, especially regarding the DRL and Side/Parking lights (Both LED or Bulb and/or combination of both).
The wire assignment for the right headlight T10 connector is the same in terms of pin numbering.
6J
6J
ciclo wrote: ↑Wed Nov 10, 2021 5:11 amFalse, that is not the BCM coding that I provided you, my BCM coding here viewtopic.php?p=585587#p585587
1-
2-
I am surprised where this autoscan coding came from I gave him what you gave earlier I will let you know immediately when I have info from an electrician about the problems
