ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
Change of software in my other TPMS unit. Editing parameters
When I bought the two TPMS units, and still did not know for certain what was the reason why I could not get the tire pressure menu in my IC, something very funny happened to me.
The two units I bought:
- the right TPMS unit,
3AA 907 273 H with F software. https://i.ebayimg.com/images/g/89kAAOSw ... -l1600.jpg (ebay). This one: viewtopic.php?f=56&t=58703&start=3645#p525012
- the wrong TPMS unit (a used part),
3AA 907 273 F with H software. The seller made a mistake, or did not know what he was selling. (no need to say where I bought it)
The wrong is this one: viewtopic.php?f=56&t=58703&start=4005#p529257
In those moments of confusion I thought that nothing was going the right way, and I thought that these TPMS units was a damn joke .. "two TPMS units bought in different places with the software exchanged". As always I thought, cheap parts, bad result.
As you all know, I made a Kit for TPMS units. I upload the image here again.
...and yesterday I used it to load the correct software for PQ25 in the wrong TPMS unit, I also did the editing of parameters (with some parameters that a forum user sent me)
The next image is intentionally blurred.
These are the parameters that the forum user sent me. (Benji58)
And here the result of the process.
And I already have another unit that works correctly for the PQ25 platform and the rest of the necessary units.
It was sold to Benji58 for a reasonable price.
Apart:
I reinstall everything by disconnecting the Kit, leaving my original VCP connected, and edit the parameters of my installed unit on rear bumper with the following configuration.
This will allow me to know if the system works correctly without having to deflate the wheels, that is, sitting in the driver's seat.
MaDwArLoCk IC (Warning TEST)
viewtopic.php?f=56&t=58703&start=3450#p522430
Apart:
- Drives: 1.2TSI 105HP DSG7
tested the ch37! thanks. thats improved alot.and yes. i agreed. feel like it does have delay to switch the light on. which channel shud do the trick and by how much? appreciate your sharing
- Drives: Polo BlueGT / Audi S5
Yes, as I said, they do illuminate a LOT, really a lot, lol... But I don't like them being yellow. I now have some cheap chinese H7 halogens, they are white, but, as always, the more the kelvins the less the lumens... I will try to put them both at 100% and see wich one i like better.
Thanks for the feedback Fernando!
Channel 35, set to 1 to test, and tell us your opinion about it.benzinkopf wrote: ↑Sun Jan 21, 2018 1:29 pm tested the ch37! thanks. thats improved alot.and yes. i agreed. feel like it does have delay to switch the light on. which channel shud do the trick and by how much? appreciate your sharing
Maybe I set this channel to 0.
.. to get the bright white in the SCLs will have to try one of those Led lamps that mentioned gtsportms. viewtopic.php?f=56&t=58703&start=4005#p529219 with a good appearance and be really functional.ORiOn wrote: ↑Sun Jan 21, 2018 4:34 pmYes, as I said, they do illuminate a LOT, really a lot, lol... But I don't like them being yellow. I now have some cheap chinese H7 halogens, they are white, but, as always, the more the kelvins the less the lumens... I will try to put them both at 100% and see wich one i like better.
Already ordered them yesterdayciclo wrote: ↑Sun Jan 21, 2018 7:39 pm .. to get the bright white in the SCLs will have to try one of those Led lamps that mentioned gtsportms. viewtopic.php?f=56&t=58703&start=4005#p529219 with a good appearance and be really functional.
i like the part where u have the Warning Test. excellent and clever!ciclo wrote: Updated
- Drives: Seat
Hi, my bcm is from 2017 beetle. Firmware 0744. I think that firmware 0744 is similar as 0744 from another bcm but can be difference in eeprom content. I have already connected new bcm to pc. Transfered coding from original bcm in car. I can see 3 virtual ecu in new bcm:ciclo wrote: ↑Fri Jan 19, 2018 8:50 amTry it with the fw of a BCM 7E0..090 /B/C from Transporter T6, not all firmwares of 7E0..090 /B/C are equal.explorer232 wrote: ↑Thu Jan 18, 2018 1:42 pmI need only reconfigure gpio port functions or reconfigure dtc masking for lights. VCP pq25 param editor is editing eeprom in cpu. 6R0 937 087H and 7E0 937 090B is still similar hw only part number in eeprom, fw version, populated pins in connector and eeprom config is difference so I think that its possible write firmware from 7E0937090B to 6R093708x. I am waiting for bcm connectors and then I will to make some research.
Please keep us informed.
- 09 Central electronics
- 19 Gateway
- 61 Battery management
So 61 battery management must be added to gateway list. Otherwise there will be error in can gateway.
At the evening I will try to connect 5f module on the confort can bus of this bcm.
At the moment there are standard DTCs
- terminal 30 for left light not connected
- terminal 30 for right light not connected
ant too much errors because I have connected only bcm.
http://i64.tinypic.com/34i0482.jpg
BUT I cant read eeprom data from new bcm, vcp param editor is not working. Problem with security access.
Is there security access code 31347 in 7E0937090b bcm ? Yesterday evening I didnt have free time to make some research with access code.
Do you have 7E0937090B bcm with 0744 firmware?
Could you like to test if in your configuration is possible establish security access with bcm?
I see that you have VCP.
- Drives: Seat
Hi, ok, thanks.
If there isnt 61 address enabled in gw list, gw throw error with incorrect configuration because device 61-BM is active on the can bus.
Yes, but beetle is pq25 platform and discovery media in beetle is MIB-PQ.
I have MIBstd from MQB platform so I must try if its working correctly in PQ25 platform
VCDS is creating standard session with bcm. But for fw/eeprom reading, writting is needed engineering session.
Could you like to test in VCP > Guided Functions > BCM PQx5 programmer if security access will be established in your case?
Thanks.
Thanks.
... If your VCP is not original I'm afraid you will not be able to access the PQ25 BCM parameters edition. No security access is necessary to this.
Mi current BCM is 7E0937090C BCM PQ25 Max4 H82 0752 and to access the parameter edition I have to configure my VCP in English, in Spanish it does not work. And yes it works like a charm with all 7E0 BCMs (.../B/C/...)
Please, share your current BCM/Gateway codings.
Saturday,20,January,2018,17:15:29:06516
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: New Battery and Test
Mileage: 29280km-18193mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77 0B
VIN: WVWZZZ6RZDY0CICLO Mileage: 29280km-18193miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
VCID: 6A87125C2730E7B8F5-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 021FE2148B385760B5-8056
Serial number: 08021613470174
Coding: 01
ROD: EV_LWSKLOVW25X_VW25.rod
VCID: 7E93EA9897947FCC95-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 38497EB6673613DA45-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 3CB02FBF48E32400B3380F916CEB9FDCDAC0672F600D30D0200000030800
VCID: 2B44949153F76D01FD-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E536AD89754FF8C95-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
VCID: 4A6752FCA790A758F5-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140E01
Shop #: WSC 00233 572 00000
VCID: 47585CE5AB63B54DDD-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002200
VCID: 68791E462706F3AAC5-803C
Address 20: High Beam Assist. (J844) Labels:. 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
Shop #: WSC 03607 002 104857
ROD: N/A
VCID: 2E438AA857E45F1C15-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
Component: IMMO H04 0805
Shop #: WSC 00000 000 00000
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A47929C2FF06778F5-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5274
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 37487CB5633315DD5D-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V15 8515
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 00788
VCID: 2F408CADD71B45251D-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 7788FC756B73951D5D-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000050821
ROD: EV_RDKBERU30.rod
VCID: 37487CB56B3315DD5D-8062
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B5474C19B270DF17D-806E
End-------------------------(Elapsed Time: 04:29)--------------------------
- Drives: Seat
Hi, ok, thanks I will try it at evening.
For params editing vcp establish service mode (engineering session) automatically, authentification via seed key algo (vcp log for info)
- Drives: Seat
Hi, so I have connected 5F module (from MQB) to komfort can bus in pq25 bcm in my config and result was very bad. Gateway throw error communication is deffective and no communication with 5f and other devices on this can bus (as when I connect 5f module to my car)
I found that problem is can bus baudrate. Infotainment module 5F from mqb is originally connected to infotainment can bus with baud rate 512kbps but komfort can bus in pq25 gw have only 128kbps. So then I reconnect 5F to drive (powertrain) can bus (this can bus have 512kbps baudrate) and viola 5f module is working now.Tomorrow I will to play with bcm params.
Chassis Type: 7E0
Scan: 01 03 04 08 09 15 17 19 25 44 4B 5F 61 0B
4B-Multifunc. Module -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 89007225160941
Coding: 3C880BE888610100003000007F0B1CC800C0400F608C0000300000000000
Shop #: WSC 00066 123 12345
VCID: 2A5A3A3445FF281197-807E
16 Faults Found:
03430 - Terminal 30 for Turn Signals and Brake Lights
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
03428 - Activation of Left Adaptive Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
03429 - Activation of Right Adaptive Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
03435 - Terminal 30 for Interior Light and Parking Light
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
00329 - Control Circuit for Unlocking Rear Lid
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
03585 - Terminal 30 for Windshield Wiper
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
03444 - Ignition Starter Switch
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
01333 - Door Control Module; Rear Left (J388)
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
01332 - Door Control Module; Passenger Side (J387)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
03591 - Control Circuit for Horn
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
01516 - Terminal 30; Left
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
00927 - Terminal 30 (Right)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
Address 15: Airbags
Cannot be reached
Cannot be reached
Address 19: CAN Gateway (J533) Labels: None
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 322200
VCID: 68DE803C9B73DA0141-803C
4 Faults Found:
01336 - Company Data Bus for Comfort System
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
01312 - Powertrain Data Bus
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
00381 - Databus Instrument Cluster
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
03406 - Control Module for Battery Monitoring
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Time Indication: 0
Address 25: Immobilizer
Cannot be reached
Address 44: Steering Assist
Cannot be reached
Address 4B: Multifunc. Module
Cannot be reached
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5F0 035 846 A HW: 5F0 035 846
Component: MU-S-N-ER 039 0480
Serial number: E1F01011120288
Coding: 04730001D70A000021110001000800002F01010401000100C6
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 2642CE0459E70C71B3-8072
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H45 0022
Serial number: SEZ8Z9N5600SJR
Data medium:
Subsystem 2 - Part No SW: 5F0 060 884 AP HW: -----------
Component: ECE 2017/18 --- 0067
19 Faults Found:
1553 - Function Restriction
B200D F0 [008] - due to Internal Communcations Error
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 12.1 V
1555 - Check Software Version Management
B201A 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
1556 - Internal Control Module Memory Check Sum Error
B2000 87 [008] - Missing message
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
0512 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
Fault Priority: 6
Fault Frequency: 3
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
0513 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
0518 - Front Right Treble Speaker
B1064 13 [009] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
0523 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
0527 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Fault Priority: 6
Fault Frequency: 3
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
0528 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
0532 - Loudspeaker Channel 5
B13A4 01 [009] - Electrical Failure
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
0537 - Loudspeaker Channel 6
B13A5 01 [009] - Electrical Failure
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
0004 - Antenna 2 for radio
B111A 11 [009] - Short to Ground
Fault Priority: 6
Fault Frequency: 14
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 12.5 V
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
0005 - Antenna Amplifier 1 for Radio
B126D 13 [009] - Open Circuit
Fault Priority: 6
Fault Frequency: 4
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
0006 - Antenna Amplifier 2 for Radio
B126E 13 [008] - Open Circuit
Fault Priority: 6
Fault Frequency: 12
Reset counter: 40
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
Fault Priority: 4
Fault Frequency: 1
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
1564 - Microphone 1
B129B 13 [009] - Open Circuit
Fault Priority: 4
Fault Frequency: 1
Reset counter: 0
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
1024 - Interface for External Media Devices (MEDIA-IN)
B1288 13 [009] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 00000000
Shop #: WSC 00066 790 00180
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
End-------------------------(Elapsed Time: 01:56)--------------------------
Very clever work, I always wondered if MQB was possible to work on PQ cars, you should start a separate topic with these testsexplorer232 wrote:Hi, so I have connected 5F module (from MQB) to komfort can bus in pq25 bcm in my config and result was very bad. Gateway throw error communication is deffective and no communication with 5f and other devices on this can bus (as when I connect 5f module to my car)
Chassis Type: 7E0 Scan: 01 03 04 08 09 15 17 19 25 44 4B 5F 61 0B 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 4B-Multifunc. Module -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Cannot be reached ------------------------------------------------------------------------------- Address 03: ABS Brakes Cannot be reached ------------------------------------------------------------------------------- Address 08: Auto HVAC Cannot be reached ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 B HW: 7E0 937 090 Component: BCM PQ25 Max4 H81 0744 Revision: B9081001 Serial number: 89007225160941 Coding: 3C880BE888610100003000007F0B1CC800C0400F608C0000300000000000 Shop #: WSC 00066 123 12345 VCID: 2A5A3A3445FF281197-807E 16 Faults Found: 03430 - Terminal 30 for Turn Signals and Brake Lights 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 03428 - Activation of Left Adaptive Light 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 03429 - Activation of Right Adaptive Light 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 03435 - Terminal 30 for Interior Light and Parking Light 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 00329 - Control Circuit for Unlocking Rear Lid 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 00975 - Heated Rear Window (Z1) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 03585 - Terminal 30 for Windshield Wiper 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 03444 - Ignition Starter Switch 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 03591 - Control Circuit for Horn 011 - Open Circuit Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 01516 - Terminal 30; Left 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 00927 - Terminal 30 (Right) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 ------------------------------------------------------------------------------- Address 15: Airbags Cannot be reached ------------------------------------------------------------------------------- Address 17: Instruments Cannot be reached ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 7E0 909 901 HW: 7E0 937 090 Component: GW-K-CAN TP20 H81 0744 Revision: B9081001 Coding: 322200 Shop #: WSC 00066 123 12345 VCID: 68DE803C9B73DA0141-803C 4 Faults Found: 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 01312 - Powertrain Data Bus 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 00381 - Databus Instrument Cluster 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 03406 - Control Module for Battery Monitoring 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 5 Time Indication: 0 ------------------------------------------------------------------------------- Address 25: Immobilizer Cannot be reached ------------------------------------------------------------------------------- Address 44: Steering Assist Cannot be reached ------------------------------------------------------------------------------- Address 4B: Multifunc. Module Cannot be reached ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: Redir Fail! Part No SW: 5F0 035 846 A HW: 5F0 035 846 Component: MU-S-N-ER 039 0480 Serial number: E1F01011120288 Coding: 04730001D70A000021110001000800002F01010401000100C6 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_MUStd4CPASE 002039 ROD: EV_MUStd4CPASE_VW37.rod VCID: 2642CE0459E70C71B3-8072 Operating And Display Unit 1: Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A Component: ABTmin_Std_Nv H45 0022 Serial number: SEZ8Z9N5600SJR Data medium: Subsystem 2 - Part No SW: 5F0 060 884 AP HW: ----------- Component: ECE 2017/18 --- 0067 Serial number: -------------------- 19 Faults Found: 1553 - Function Restriction B200D F0 [008] - due to Internal Communcations Error Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 40 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 1555 - Check Software Version Management B201A 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 1556 - Internal Control Module Memory Check Sum Error B2000 87 [008] - Missing message Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 40 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 0512 - Rear Right Bass Speaker B1067 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 0513 - Rear Right Treble Speaker B1068 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 0518 - Front Right Treble Speaker B1064 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 0523 - Front Left Treble Speaker B1061 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 0527 - Rear Left Bass Speaker B1065 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 0528 - Rear Left Treble Speaker B1066 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 0532 - Loudspeaker Channel 5 B13A4 01 [009] - Electrical Failure Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 0537 - Loudspeaker Channel 6 B13A5 01 [009] - Electrical Failure Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 0004 - Antenna 2 for radio B111A 11 [009] - Short to Ground Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 14 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.5 V Status of antenna 2 for radio-Antenna current: 0 mA Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV 0005 - Antenna Amplifier 1 for Radio B126D 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 4 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V Status of antenna 1 for radio-Antenna current: 0 mA Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV 0006 - Antenna Amplifier 2 for Radio B126E 13 [008] - Open Circuit Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 12 Reset counter: 40 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V Status of antenna 2 for radio-Antenna current: 0 mA Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV 2565 - GPS Antenna B1054 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 1564 - Microphone 1 B129B 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 0 Mileage: 1048574 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V 1024 - Interface for External Media Devices (MEDIA-IN) B1288 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 0 km Date: 2000.00.00 Time: 00:00:00 Voltage terminal 30: 12.1 V ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb Part No SW: 7E0 907 534 HW: 7E0 937 090 Component: Batt.regelung H81 0744 Serial number: 89007225160941 Coding: 00000000 Shop #: WSC 00066 790 00180 VCID: 68DE803C9B73DA0141-803C 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Time Indication: 0 End-------------------------(Elapsed Time: 01:56)--------------------------
