rear demister polo 2018
- Drives: polo 1999 now sold and got a 2018 1LT po
I've got a 1lt 2018 polo with a heated rear windscreen but cannot find a switch to switch it on or off, last week the window was misted up and I could see that the heating bars were working, was it because I had the front windscreen demister switched on to clear the front windscreen?
Re: rear demister polo 2018
if your vehicle is a 6C polo then the heated rear window switch is located above the infotainment screen along with the other switches for heated seat,stop/start etc
If its a AW polo im not sure of its postion some one will let you know
A picture of the interior would be helpful. If your polo is AW/2G, it's on the heating panel below the radio.
Rear demist button in a 2018 Polo AW is in the location circled in green in the picture below;
If you’ve got dual zone climate control rather than manual air con, then it’s the button circled in green on the picture below;
- Platinum Member
That light that shines on the compartment looks so nice and useful.
many thanks to SRGTD for sending the photo, It was the AW version, I've never seen the button before all sorted now, thanks
