rear demister polo 2018
hyrama
Drives: polo 1999 now sold and got a 2018 1LT po
Post by hyrama »
I've got a 1lt 2018 polo with a heated rear windscreen but cannot find a switch to switch it on or off, last week the window was misted up and I could see that the heating bars were working, was it because I had the front windscreen demister switched on to clear the front windscreen?
CarbonChaos
Re: rear demister polo 2018
Post by CarbonChaos »
if your vehicle is a 6C polo then the heated rear window switch is located above the infotainment screen along with the other switches for heated seat,stop/start etc
If its a AW polo im not sure of its postion some one will let you know
A picture of the interior would be helpful. If your polo is AW/2G, it's on the heating panel below the radio.
Rear demist button in a 2018 Polo AW is in the location circled in green in the picture below;
If you’ve got dual zone climate control rather than manual air con, then it’s the button circled in green on the picture below;
That light that shines on the compartment looks so nice and useful.
hyrama
Post by hyrama »
many thanks to SRGTD for sending the photo, It was the AW version, I've never seen the button before :oops: all sorted now, thanks
