benzinkopf wrote: Hehe.
gti16
- Drives: VW Polo 6r 1.6 TDI
On TPMS I did not get anything, I am not able to encode the IC with my cable. Strange because I've managed to code before with this cable.
You talk about buying the original cable, really mine is not but does it make any difference to be original or not? What is the value of the original?
Free updates and technical support. Everyone knows they do a great job for a wide global community of customers and users.gti16 wrote:You talk about buying the original cable.... but does it make any difference to be original or not?
All information here: http://www.ross-tech.com/products.php
If you want a fake version, search on eBay, amazon, aliexpress ... etc ...
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
This could be because your IC doesn't support RKA. Could you please share the 17 Instrument autoscan info.gti16 wrote:....
Another problem I found is I could not activate the TPMS in the IC. I activate the function and it saves, it does not give an error message but it does not save the change. In the past this function has worked but now it is not working, I think it has been since the BCM change.
For example I couldn't activite brake pads wear indication. My MFA+ (Maxidot) IC rejects coding. At least IC firmware upgrading and modifiing is needed. Like here Eugene Zzzhuk provided
https://www.drive2.ru/l/458272874118037835/
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Same like when i tried to enable Gear Shift + - Indicator on my IC(when ure driving in manual mode). It accepted the code but not save. Not sure why i can't enable it.
try enabling brake pad wear indicators... you'll run into the same. VCDS has a documented byte for it but is simply rejected with a code 31.
gti16's Autoscan viewtopic.php?f=56&t=58703&start=2775#p515790firegrafik wrote:This could be because your IC doesn't support RKA. Could you please share the 17 Instrument autoscan info.gti16 wrote:....
Magic things ... well done!firegrafik wrote: Like here Eugene Zzzhuk provided
Have you installed your new GTI IC with MFA+ ?benzinkopf wrote:Same like when i tried to enable Gear Shift + - Indicator on my IC(when ure driving in manual mode). It accepted the code but not save. Not sure why i can't enable it.
It seems that Volkswagen forgot to integrate many things in 6R Instrument Cluster.iichel wrote:try enabling brake pad wear indicators... you'll run into the same. VCDS has a documented byte for it but is simply rejected with a code 31.
Ah!... many thanks for email reporting. Cool!!!
gti16
Is compatible because it has worked before changing the BCM. I have an autoscan before the BCM exchange that has the right coding for tpms.This could be because your IC doesn't support RKA. Could you please share the 17 Instrument autoscan info.
benzinkopf
Nope. Ive to cancel the order. The seller from Aliexpress responded that their selling chinese version of IC with chinese character and they can flash english character for me only for 500 usd. With the exceeding rates of usd last time, ive to cancel. [emoji24]
Bad news.ciclo wrote:Have you installed your new GTI IC with MFA+ ?benzinkopf wrote: .... ive to cancel.
You already know that if in the future you want to install the HBA system you have to install an instrument cluster with MFA+
benzinkopf
Really bad news. Its ok. Will see how it goes in the future. At the moment, will install bcm max first and utilize its function to the max whenever possible with my stock IC.
hi ciclo
How did you access address 04
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 08021613470174
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7E9BE2908F8C67D0C6-802A
Coding: 01
Hi wamba, due to latest versions of VCDS.
ok thank's
firegrafik
Hello to everyone!
There is greatest news. The full type tyres pressure control (RKDS) is possible on Polo6R.
Eugene aka ZZZhuk is wisard
https://www.drive2.ru/l/461592849478059310/
