benzinkopf wrote: Hehe.
:lol:
gti16
Drives: VW Polo 6r 1.6 TDI
Post by gti16 »
On TPMS I did not get anything, I am not able to encode the IC with my cable. Strange because I've managed to code before with this cable.
You talk about buying the original cable, really mine is not but does it make any difference to be original or not? What is the value of the original?
gti16 wrote:You talk about buying the original cable.... but does it make any difference to be original or not?
Free updates and technical support. Everyone knows they do a great job for a wide global community of customers and users.
All information here: http://www.ross-tech.com/products.php
If you want a fake version, search on eBay, amazon, aliexpress ... etc ...
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
gti16 wrote:....
Another problem I found is I could not activate the TPMS in the IC. I activate the function and it saves, it does not give an error message but it does not save the change. In the past this function has worked but now it is not working, I think it has been since the BCM change.
This could be because your IC doesn't support RKA. Could you please share the 17 Instrument autoscan info.
For example I couldn't activite brake pads wear indication. My MFA+ (Maxidot) IC rejects coding. At least IC firmware upgrading and modifiing is needed. Like here Eugene Zzzhuk provided
https://www.drive2.ru/l/458272874118037835/
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Same like when i tried to enable Gear Shift + - Indicator on my IC(when ure driving in manual mode). It accepted the code but not save. Not sure why i can't enable it.
try enabling brake pad wear indicators... you'll run into the same. VCDS has a documented byte for it but is simply rejected with a code 31.
firegrafik wrote:
gti16 wrote:....
gti16's Autoscan viewtopic.php?f=56&t=58703&start=2775#p515790
firegrafik wrote: Like here Eugene Zzzhuk provided
Magic things ... well done! 8)
benzinkopf wrote:Same like when i tried to enable Gear Shift + - Indicator on my IC(when ure driving in manual mode). It accepted the code but not save. Not sure why i can't enable it.
Have you installed your new GTI IC with MFA+ ?
iichel wrote:try enabling brake pad wear indicators... you'll run into the same. VCDS has a documented byte for it but is simply rejected with a code 31.
It seems that Volkswagen forgot to integrate many things in 6R Instrument Cluster. :mrgreen:
Ah!... many thanks for email reporting. Cool!!!
gti16
Post by gti16 »
Is compatible because it has worked before changing the BCM. I have an autoscan before the BCM exchange that has the right coding for tpms.
benzinkopf
Nope. Ive to cancel the order. The seller from Aliexpress responded that their selling chinese version of IC with chinese character and they can flash english character for me only for 500 usd. With the exceeding rates of usd last time, ive to cancel. [emoji24]
ciclo wrote:Have you installed your new GTI IC with MFA+ ?
benzinkopf wrote: .... ive to cancel.
Bad news. :|
You already know that if in the future you want to install the HBA system you have to install an instrument cluster with MFA+
benzinkopf
Really bad news. Its ok. Will see how it goes in the future. At the moment, will install bcm max first and utilize its function to the max whenever possible with my stock IC.
wamba
Drives: polo 1.2tsi
Post by wamba »
hi ciclo
How did you access address 04
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 08021613470174
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7E9BE2908F8C67D0C6-802A
Hi wamba, due to latest versions of VCDS.
wamba
Drives: polo 1.2tsi
Post by wamba »
ok thank's :wink:
firegrafik
Hello to everyone!
There is greatest news. The full type tyres pressure control (RKDS) is possible on Polo6R.
Eugene aka ZZZhuk is wisard
https://www.drive2.ru/l/461592849478059310/
Locked
