Polo 6R ABS CODING
Posted: Fri May 20, 2016 10:57 pm
Can anyone post their Polo 6R ABS Coding for me. I have lost mine.
I own a VW Polo 6R 2011 1.2 TDI RHD 5 Door.
Thank You!!
This is the Auto-Scan:
VCDS Version: Release 15.7.4 (x64) Running on Windows 8.1 x64
Data version: 20160216
http://www.Ross-Tech.com
Friday,20,May,2016,21:11:49:33719
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56 77
VIN: WVWZZZ6RZCU015153 Mileage: 48200km-29950miles
03-ABS Brakes -- Status: Not registered 0011
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 A HW: 03P 907 425 A
Component: R3 1.2 DCM3.7 H06 8411
Revision: 11002001 Serial number:
Coding: 00114010002500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TDI03103P906021A 001010
ROD: EV_ECM12TDI03103P906021.rod
VCID: 26438C535964BA0E24-8072
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 31414 790 31414
VCID: 071DE1D7B2AE83063F-8052
4 Faults Found:
03306 - Coding Not Valid
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 96
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:04:03
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x259D
Hex Value: 0x00FF
Hex Value: 0x7F81
Hex Value: 0x7FF8
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x149D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B9D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x209D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
End-------------------------(Elapsed Time: 02:45)--------------------------
Thank You!!
Revision: --------
4 Faults Found:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 96
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:04:03
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x259D
Hex Value: 0x00FF
Hex Value: 0x7F81
Hex Value: 0x7FF8
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x149D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B9D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x209D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
