ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙♂️
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
I have Hex+V2 VCDS.
The only difference to fitting the 7,5 headlights on a 7 should be the front fenders.
- 30D68021-CD3A-4727-991C-4D6BBE317923.jpeg (31 KiB) Viewed 5473 times
Well, a lot of the coding and adaptation work can be done with VCDS, but you will need to have the VAS to do various work with ODIS-S ONLINE for the correct installation of the new units you need to install.
As a recommendation and if you are determined to do it, I would start with the BCM and the GW.
These are the latest models 'HIGH' for Golf 7.5 BQ1 (my wife's golf):
(there are two GW, one is for a friend )
In no case will it be a cheap installation.
- Mart!n-GTI-DK
- Platinum Member
I figured as much... But I would be more than happe with the Mk7 Golf R headlights. as an upgrade to my stock B-Xenon's. But I can't seem to find a set anywhere
Please illustrate me, what are the differences between your Bixenon Golf MK7 headlights and Golf R MK7 headlights?
In the ETKA I see that there are some MK7 LED headlights prior to the MK7.5 LED headlights, is that what you mean?
Talking about led lights, today I found out that Osram has dynamic turning lights for the car mirrors.
I don't remember if your car has the OEM ones, but I putting the link here in case you or someone else is interested.
https://www.osram.com/am/dmi_vehiclefinder.jsp
- Mart!n-GTI-DK
- Platinum Member
The lights are almost identical. BUT only the Golf R have light in both the "U" DRL's. And all others with xenon lights only have light in the outer "U" in both headlights. And also the R has LED turnsignals in the headlights aswell.
You can see them in this video.
https://www.youtube*.com/watch?v=DaiVWgADMKU
I don't have the dynamic indicators in the mirrors. I don't really like them... To much carnival lights for my taste.
But I have made "semi dynamic" indicators in the taillights with a timer relay.
https://www.youtube.com/watch?v=o8UbmRuwEhk
Ok, thank you very much Martin.
I like the effect you have achieved with the rear indicators, instead of a soft effect of the original dynamic indicators the yours are clear and determined.
It's as if your dynamic indicators say ... get out of the way ...
- Mart!n-GTI-DK
- Platinum Member
Haha yeah. Only the 7,5 vane with dynamic Indicators. So Inhad to get creative.
Thank you very much for the link exantas, I had seen it a long time ago, but it is good to have it handy. OSRAM is one of my favorite brands.exantas wrote: ↑Sat Oct 03, 2020 10:30 pm Talking about led lights, today I found out that Osram has dynamic turning lights for the car mirrors.
I haven't thought about installing the dynamic turn signals on the mirrors yet (maybe I should have done when I ran the BSD wires through the mirrors).
A gift image for those who like details:
Crystal clear.
There are several possibilities with new functions for the dynamic turn signals in the mirrors (LED with blue color when opening the car - Aliexpress -) but as Martin says it would be a carnival of lights.
In case I installed them, I would buy them in the accessories section of the official VW website, maybe they are the same as OSRAM's.
In the downloadable catalog of the VW accessories store for each country can be seen, also in the accessories section of the official websites.
In my case:
Golf 7.5 New BCM DH and GW AC
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 0312
Serial number: 72007150025702
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 015F7878518EE1635DD-8054
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180621 043 0551
Serial number: 180705074106
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SBY18M08D06H04M32S34
Coding: 06A8DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000002081804401346
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 09012020001767
Coding: 030100047F085700DA000258080F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW37.rod
VCID: 70B92DBC6A24F8EBA23-8024
Alternator:
Component: 4-01-02-01-04
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H18 0052
Serial number: 39190002063230049307
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 9353818504
------------------------------------------------------------------------------- Everything works ... like a charm!
(I mean it's totally possible)
Edition, April 18, 2022.
Flasheo hardwariano.
https://www.youtube.com/embed/N_4nhspzY ... autoplay=1
Coding: 0E4DDD
Coding: 06A8DD
Alternator:
Coding: 2CFFFF
Tuesday,06,October,2020,16:48:00:32438
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4526.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW License Plate: NEW BCM DH AND NEW GW AC .....OK!
Mileage: 33447km-20783mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 3C 42 44 52 5F 65
VIN: WVWZZZAUZKPCICLOW Mileage: 33447km-20783miles
Address 01: Engine (J623-DKRF) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 L HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 6198
Revision: D7H20000
Coding: 01190032234415082000
Shop #: WSC 00046 028 00070
ASAM Dataset: EV_ECM10TFS01104C906025L 002003
ROD: EV_ECM10TFS01104C906025L_002.rod
VCID: 290F00D8897EC92325D-807C
Readiness: 1010 0001
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DD HW: 5Q0 614 517 AC
Component: ESC H25 0424
Revision: 00000000 Serial number: 51998000000173
Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A4082430B00000012121212B835351919323200
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 76B51BA40840D6DB78F-8022
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 00020003200110011005004000101022
Shop #: WSC 00028 028 00068
ASAM Dataset: EV_ACClimaBHBVW37X 006145
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 6D8734C87D161503895-8038
Fresh Air Blower Front:
Geber für Kältemitteldruck/Kältemitteltemperatur:
Air quality sensor:
Coding: 0E4DDD
Coding: 06A8DD
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000308417318277
Coding: 0271165841
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 51FF8838C16ED1E38DD-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 2B00670119FFC728949C810560400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D1B16C0E1C344B36B-8010
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4F1CUQ
Coding: 98CCC000000000005C0000CF000800000065
Shop #: WSC 00028 028 00064
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 094F605869BEA92305D-805C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H37 0350
Serial number: 34169667E30071820325
Coding: 333135
Belt Pretensioner right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H37 0350
Serial number: 34169668E31071830145
Coding: 333135
Side Sensor Driver Front:
Subsystem 3 - Part No SW: ----------- HW: 480 002 307 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000F8745C23S
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 4 - Part No SW: ----------- HW: 480 002 807 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000000EC18233G
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 5 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001A729FD154210-
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001A929FD1515577
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 480 402 306 18
Component: FrontSensor_D 003 6149
Serial number: 3550001A326704A3C63.
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 750 D HW: 5G1 920 750 D
Component: KOMBI 310 2700
Coding: 07A52A802688000801887A0D1401000000000000
Shop #: WSC 00200 935 01530
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 280905DC9274F02B3A3-807C
Alternator:
Coding: 2CFFFF
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 3G0 857 511 BD HW: 3G0 857 511 BD
Component: FLA H01 0010
Revision: AA001001
Coding: 0404000000000000000000
ASAM Dataset: EV_HighBeamAssisAU33X 001019
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 6B833AD043021B33971-803E
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0519386082
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D27C4886DF64583795-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0519601132
Coding: 020111
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000305474246
Coding: 00150320D000048000001000
Shop #: WSC 00020 999 12345
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 48C9A55C3234102BDA3-801C
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000009798407
Coding: 010000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1081
Coding: 031F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B322B01B32C3F35F1-8026
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000336638884
Coding: 00150320DE00048000001000
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: 47CBA6603F2A1F53D39-8012
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000009846262
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0891
Serial number:
Coding: 02731001FF0000005111000100880A001F0500D401200100CF
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 323DE7B4A4A88AFB947-8066
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV2691212
Data medium:
Subsystem 2 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000250801
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3431E1AC5EBC84CB86B-8060
End----------(Elapsed Time: 01:20, VBatt start/end: 13.4V/13.4V)-----------
I deeply appreciate all your views. Thank you very much!
Btw, you can click Like or Dislike, whatever you do is good for me.
Here begins a new process / project to hang out in my spare time during the fall - winter.
At this point I just want to comment that everything I am going to do is already installed in my thoughts, that is, if I diagnosed my thoughts with VAS / VCDS / VCP, the result of the diagnosis would be all OK!
Golf 7.5 Level sender ((torsion beam rear axle)).
+ 357 972 740 D https://www.a4-freunde.com/showwiki.php ... uebersicht
G76
G76
Golf 7.5 Behind SC fuse box. Supply points. (+30, +15)
Previous info:
viewtopic.php?p=572693#p572693
viewtopic.php?p=574274#p574274
I'll add a new fuse holder for +15 and +30 signals in an 'OEM' way ... to again avoid removing the SC fuse box, which is absurd and ridiculous.
Previous info:
Golf 7.5 Wiring diagram J745 (FCM)
I already told you once that I want a little of what you smoke ...
J386 (convenience)
J386 (convenience)
Golf 7.5 LED Headlights (8IX, 8IU). Wiring.
I will make my own wiring loom. In fact I am going to make two wiring for Golf MK7.5 LED Headlights, two wiring for J745 FCM, two wiring for the Lever sender G76 and two wiring for the part of the wiring dedicated to the fuses.
Maybe I'll put the second wiring up for sale... (because it is not yet sold on Aliexpress...)
