iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
A follow up on earlier post: https://uk-polos.net/viewtopic.php?p=607878#p607878
Parts list:
So I just pretty much did a DQ250 SYP to DQ500 SDM swap, all OEM.
What do you need to make it work?
Well… I know!
So let’s start with the gearbox itself, I took an SDM gearbox from a Passat 2.0 TSI CHHB Alltrack. QBB is pretty much identical.
VIN for reference: WVWZZZ3CZHE001852
You'll need a different, bigger flywheel. You could maintain your starter but I decided to take a new one as well.
Next up you’ll need a different final drive (the angular drive for the prop shaft to the rear). There are two options, the Linamar 0CP and the Magna 0A6 families. I went for the Linamar since it's broadly available.
The pendulum support is different and I decided to replace motor and gearbox mounts as well. I took the RS3 gearbox mount and an OEM engine mount.
For cooling you'll need to add a different regulator valve and some plumbing, since the DQ250 regulator sits on top of the gearbox. The DQ500 one will sit next to the engine water pump on the side of the gearbox.
The gear lever cable will fit your existing lever, just replace the cable 3Q0713266Q
Gearbox: SDM
Flywheel: 06J105266RAQ
Lever cable: 3Q0713266Q
Coolant hose: 3Q0121058B
Coolant valve: 5Q0906457K
Support for valve: 3Q0121093AJ
Pendulum support: 5Q0199855AH
Bolts: N10784701 + N10784801
Gearbox mount: 8V0199555A (this is hydraulic mount from RS3 / TTRS)
Final drive: 0CP409053x
Support bracket: 0CP409905H
Oil: G052145S2
Drive shaft left: 3Q0407271AH
Drive shaft right: 3Q0407272BH
Drive shaft right heat shielding: 5QJ407720A/B
Electrical connector: 3D0973993
It's pretty much plug and play all the way, you'll be needing some new bolts probably for the ones you destroy, lose, strip and are too short.
4x 91088901 bracket 0CP
1x N90956402 bracket 0CP
8x WHT009773 flywheel
2x N10717701 coolant regulator
2x N01508210 coolant regulator
Gearbox to engine (all x1):
N91200901
N91200901
N90956402
N91191701
N10665601
N91182402
N10665601
N91030102
N91030102
N91235401
The mechatronic is up to 2018 the continental one. You can not immo off it so you'll either have to learn it OEM via ODIS online, or you'll have to get yourself a Bosch mechatronic and kill the immo on that.
The wiring is very simple. The terminals of the DQ250 will fit the DQ500 plug.
DQ250 0D9/02E
T20/
1
2
3
4
5
6
7
8
9
10	can hi
11	+30
12
13	+15
14
15	can lo
16	GND
17	ECU 94/40 = D102
18	+30
19	GND
20	ECU 94/93
DQ500 0DL/0BH
T16/
1
2	ECU P/N	91/58 = D102 = 94/40
3
4	ECU P/N 91/88 = 94/93
5
6	can hi
7	can low
8
9	+30
10
11
12
13
14
15	+15
16	GND
So since you're all very interested in my DQ500, I'll tell you a bit more about my E85 Flex Fuel coming up.
Now it's not very popular here in the Netherlands but in for example France it's widely available.
It consists of two parts (as for every retrofit), it's hardware and software.
The hardware is:
- The sensor the Continental ethanol sensor 06H907811 /A, later went into the 06K907811 (also sold as 8K0907253 /A /B as a set with the bracket).
- 3-pin connector 4H0973703
- Some fuel quick connectors for 5/16 fuel line and 8mm hard pipes (amazon)
The wiring, we take it from a CFKA Audi A4 2.0 TSI EA888 engine
Pin 1 is power, terminal 87 from i.e. the diverter valve
Pin 2 is GND
Pin 3 goes to ECU pin 71 for Simos 18
It will require some modification of the ECU software:
Furthermore it needs to enable PID 52:
summary:
lc_fac_afu_ratio_conf = 00 (this will enable the sensor)
lc_fac_afu_ratio_man_act = 00 (this will disable the manual e-level in calibration)
c_state_srv_1_pid[N][10] is the bitfield that contains the PID for ethanol content (PID52).
2 new tables in the CAL, one as an ignition modifier (rpm vs airmass) and the other to scale the ignition modifier based on ethanol content.
I ordered all the parts and I'll wire it up soon.
Inspired by some posts on golfmk7.com
I'm mostly doing it for the nerd-factor and the possibility of being able to drive on sustainable fuels.
It might also come with a power boost, but I'm expecting to max out my stock internals.
The new rear differential in place :mrgreen: Drive shaft is 3 cm short though :lol: :lol:
I'll resolve it with an Arteon prop shaft probably, now it's a double hardi disc.
https://imgur.com/a/gST1vXD
just discovered the 2025 S3 will also offer the torque splitting rear diff: https://www.hagerty.com/media/news/euro ... r-fingers/
--> https://forums.ross-tech.com/index.php?threads/40192/
So cars with the rear diff:
MY2021+ VW Tiguan R
MY2021+ VW Arteon R
MY2020+ VW Golf 8R
MY2020+ Audi RS3 8Y
MY2025+ Audi S3
MY2018 VW Passat R :mrgreen:
Monday,28,April,2025,09:19:49:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
www.Ross-Tech.com
Workshop Code: 108 31889 005361
VIN: WVWZZZ3CZJEiichel   License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 2B 36 3C 42 44
          47 4B 52 5F 65 69 6C 6D A5 BB BC CA D6 D7 8126 8127
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. --OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- OK 0000
D7-Light Ctrl Right 2 -- OK 0000
8126-Trq distrib RearL axle -- Status: OK 0000
8127-Trq distrib RearR axle -- Status: OK 0000
Address 01: Engine (J623-CJXB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---    CVN: B7DB7878
   Coding: 0925003A2476050B3004
   Shop #: WSC 30389 123 56831
   ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
   ROD: EV_ECM20TFS0205G0906259J.rod
   VCID: 313FE88591ABBF42304-8064
   VINID: 9E69EAAAA0D3A9A54008518520274044B7
Readiness: 0010 0000
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0DL 300 012     HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5301
   Revision: 00H10V01    CVN: B537C3CB
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021.rod
   VCID: 66954BD968E528FA156-8032
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-VWR-V1.clb
   Part No SW: 5Q0 614 517 GS    HW: 5Q0 614 517 BP
   Component: ESC           H35 0993
   Revision: 00000000    Serial number: 60863000000564
   Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296758842508842A94A000000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100VWR 001005
   ROD: EV_Brake1UDSContiMK100VWR.rod
   VCID: 0849656142B1DE8AC7A-805C
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0577965047 Dataset Number: V03935321YJ 0001
   Coding: 1F20200727
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB_004_VW37.rod
   VCID: 48C9A56102311E8A07A-801C
   Rear lid opener control module:
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8001216
Address 06: Seat Mem. Pass (J521)       Labels: None
   Part No SW: 3Q0 959 760 D    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0024
   Serial number: Y0006PKA28228 Dataset Number: V03935285VX 0001
   Coding: 001000020000050081C481808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: N/A
   VCID: 3C21C9B146E9422A932-8068
No ASAM data for: "EV_SeatMemorPasseSide" (VW48)
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 3G8 907 044 T    HW: 3G8 907 044 T
   Component: Climatronic   H10 0221
   Coding: 12010024104411011115500D0018592A
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
   ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
   VCID: 3E25C3B950F5503ABD6-806A
   Air quality sensor:
   Humidity sensor: exterior:
   Rear air conditioning block 1:
   Subsystem 3 - Part No SW: 11A 907 049 A    HW: 11A 907 049 A
   Component: E265 KPH SH  H02 0183
   Serial number: G04S01.11.2100972191
   Coding: FFFFFF
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q1 937 084 B    HW: 5Q1 937 084 B
   Component: BCM MQBAB HO  H44 0512
   Serial number: 02102311001826 Dataset Number: V03935381P  0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 3829D5A172D16E0A77A-806C
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170615  042 0607
   Serial number:         170629234856
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Component: G397_RLFSS  H06 0002
   Serial number: 22181601X81A955555A0
   Coding: 02005D
   Light switch:
   Subsystem 3 - Part No SW: 3G8 941 633     HW: 3G8 941 633
   Component: E1 - LDS MQB  H01 0032
   Serial number: 19 04 2017  10000901
   Anti-theft alarm system sensor:
   Subsystem 4 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL23010051V
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000070188699
   Blower 1 for left front backrest:
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0158736
   Blower 1 for left front seat cushion:
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0096892
   Blower 1 for right front backrest:
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0145994
   Blower 1 for right front seat cushion:
   Subsystem 9 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0146336
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 L    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0074
   Serial number: 000308417617172 Dataset Number: V03935315EN 0001
   Coding: 8A79267951
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 59EF7025A99B9702A84-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V315
   Coding: 351F5FFBDFFFCF28979F813681500D800000000000B9C00032
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 47CBA65D0F2F11F20E0-8012
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 25061741350001 Dataset Number: V03935290WM 0001
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392FD0A549DB7702884-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CP    HW: 3Q0 959 655 CP
   Component: Airbag VW21   006 0721
   Revision: --------    Serial number: 003Z4PGADL1% Dataset Number: V03935283XG 0001
   Coding: 98FCC0C0008000005C5400CF000800000065
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0E45537920D580BA0D6-805A
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705 0031T01500
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Component: BeltPretRevFR  106 1032
   Serial number: 3G1857706G0185R01460
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 606 17
   Component: SideSensor_Df  008 0887
   Serial number: 357000000000507D3628
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 454 001 806 17
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000008D140C62J
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Dr  301 0148
   Serial number: 3510091305210000000U
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Pr  301 0148
   Serial number: 352002F2F52100000009
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 454 801 406 17
   Component: FrontSensor_D  304 0149
   Serial number: 3550040279610000000%
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 KT    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0265
   Revision: FF035035    Serial number: 20170828500092 Dataset Number: V03935250KY 0001
   Coding: 8410
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3G0 920 791 D    HW: 3G0 920 791 C
   Component: KOMBI         406 4191
   Coding: 07AD0898FE8C000C01887F0F3001000080000000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 2A0DFFE9BC7DCC9AF1E-807E
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 K    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0080
   Coding: 9309
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   ROD: EV_AuxilParkiHeateWOS.rod
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000276932
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5502
   Serial number: 06071710802132 Dataset Number: V03935278KN 0001
   Coding: 0B0B00347F015900DB00025E9C0F00010001070000000000000000000000
   Shop #: WSC 00046 123 12345
   GVL: 015E3C0008000600C0FC80000006CC0010000000000200000030000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFEBD177F9932F60-802A
   Generator:
   Component: 4-00-03-00-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 C    HW: 1EA 959 442 C
   Component: MFL  H03 0217
   Serial number: 17038315050562101970
   Coding: AF0B00
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H10 9070
   Serial number: 5131394104
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: U13DCAC  H26 0780
   Serial number: 0066181
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 3003201700010095
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0032
   Serial number: 17000160250002
   Coding: 0800000000000000
   Shop #: WSC 05311 115 00065
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71BF2885512BFF42704-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Serial number: Y0006QFD15173 Dataset Number: V03935285VX 0001
   Coding: 001000020000150081C481808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000591782366  Dataset Number: V03935345YL 0001
   Coding: 62954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000606636104
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS003 0350
   Serial number: YE007VFP28434 Dataset Number: V03935363WB 0001
   Coding: 00359A20D200028200011000
   ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 4ACD9F691C3DEC9A11E-801E
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5082
   Dataset Number: V03935339RG 0001
   Coding: 93070000
   Shop #: WSC 00015 115 00319
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00RUVL Dataset Number: V03935264BQ 0001
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001018
   ROD: EV_AMPMst16C3Gen2ALPI_VW48.rod
   VCID: 6B833AED730715924A8-803E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 01071710801233 Dataset Number: V03935339UR 0001
   Coding: 000000060100035207007F010A0000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001_VW37.rod
   VCID: 72BD2789542DC45A89E-8026
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS003 0350
   Serial number: YE007VF20444B Dataset Number: V03935358AV 0001
   Coding: 00359020DE00028200011000
   ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 49CFA065193BE782184-801C
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 022 D    HW: 5NA 035 022
   Component: MU-H-LND-EU   H54 1367
   Serial number: A846F0JS020395 Dataset Number: V03935262VW 0001
   Coding: 02840201000000005111110200880A301F0106E4012004009F
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_VW37.rod
   VCID: 3431E1916EB98A6A5B2-8060
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT1915518
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 821 CG    HW: -----------
   Component: ECE 2024  --- 0350
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 40000000081630 Dataset Number: RDKS_TinyQ_ 1017
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0446947174 Dataset Number: V03935259HF 0001
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW37.rod
   VCID: 42DDB749240D34DAD9E-8016
Address 6C: Back-up Cam. (J928)       Labels:* None
   Part No SW: 5Q0 907 556 E    HW: 5Q0 907 556 E
   Component: Areaview 2    H34 0617
   Serial number: C855711JV003395 Dataset Number: V03935374AY 0001
   Coding: 01840200E70F200004314817
   Shop #: WSC 33000 790 00534
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
   VCID: 3B23CAAD43E745129A8-806E
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0265
   Revision: --------    Serial number: 31344982200000 Dataset Number: V03935262CS 0001
   Coding: 02A8
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   ROD: EV_DeckLidCONTIAU736_VW37.rod
   VCID: 46D5AB59082508FAF56-8012
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1421
   Serial number: E80320003220200 Dataset Number: V03935411EY 0001
   Coding: 0004019821FAC02888DF14001020004000218000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW48.rod
   VCID: 3635DB9978C5987A656-8062
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007VBO10863 Dataset Number: V03935306SB 0001
   Coding: 000490200100028000001000
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   ROD: EV_DCU2RearDriveMAXHKLO.rod
   VCID: 4CC199711649F2AA232-8018
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS005 0350
   Serial number: YE007VBO13878 Dataset Number: V03935306RQ 0001
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
   ROD: EV_DCU2RearPasseMAXHKLO.rod
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: V03935218DJ 0001
   Coding: 208040748202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   VCID: 372BD69D7FCF61727E0-8062
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW37.rod
   VCID: 16753B191805787A456-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H09 0003
   ASAM Dataset: EV_LEDModRightMELCOAU736 001004
Address 8126: Trq distrib RearL axle (J492)       Labels: 08E-907-554.clb
   Part No SW: 08E 907 554 H    HW: 08E 525 130
   Component: 4Motion       H05 0125
   Serial number: 012WDYM
   Coding: 00101000
   ASAM Dataset: EV_TorquSplitLeftMAGNA 001005
   ROD: EV_TorquSplitLeftMAGNA.rod
   VCID: 3333E28D6BB78D52428-8066
Address 8127: Trq distrib RearR axle (J492)       Labels: 08E-907-554.clb
   Serial number: 012WEOT
   Coding: 00010100
   ASAM Dataset: EV_TorquSplitRightMAGNA 001005
   ROD: EV_TorquSplitRightMAGNA.rod
End----(Elapsed Time: 02:32, VBatt start/end: 12.6V/11.8V. VIgn 11.8V)-----
------------------------------0 Faults Found------------------------------
coming soon:
- A5 cam SW 1423 / J
- Soundaktuator
- Experiments with eBKV
- Experiments with ethanol sensor fur running E85
Out: 5Q0121407AA (upgraded when I moved from G13 to G12 Evo, this is the bottle without silicate)
In: 5WA121407F
Updated A5 cam SW to 1423 (J):
to
   Part No SW: 2Q0 980 653 J    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1423
   Serial number: E80320003220200 Dataset Number: V03935436GF 0002
   VCID: 3C21C9B146E9422A933-8069
full scan
Thursday,01,May,2025,17:17:20:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(VMWare)
VCDS Version 25.3.1.0 (arm64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
www.Ross-Tech.com
VIN: WVWZZZ3CZJiichel   License Plate:
6C-Back-up Cam. --  Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
   VCID: 313FE88591ABBF42305-8065
Readiness: 0000 0000
   Coding: 0014
   VCID: 66954BD968E528FA157-8033
   Coding: 0FEC6B8FD1222371477D070560CB69F0D68BC4E2E00696759842508842A84A000000000012121212B835351919323200
   VCID: 0849656142B1DE8AC7B-805D
   Coding: 1F20200727
   VCID: 48C9A56102311E8A07B-801D
   ROD: N/A
   VCID: 3E25C3B950F5503ABD7-806B
   Air quality sensor:
   Coding: FFFFFF
   VCID: 3829D5A172D16E0A77B-806D
   Coding: 0F4DFD
   Coding: 02005D
   Light switch:
   Alarm horn:
   Coding: 8A79267951
   VCID: 59EF7025A99B9702A85-800D
   VCID: 47CBA65D0F2F11F20E1-8013
   VCID: 392FD0A549DB7702885-806D
   VCID: 0E45537920D580BA0D7-805B
   Coding: 80000D
   Coding: 80000D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 8410
   VCID: 2A0DFFE9BC7DCC9AF1F-807F
   Coding: 9309
   VCID: 7F5BFEBD177F9932F61-802B
   Generator:
   Coding: AF0B00
   Analog clock:
   VCID: 71BF2885512BFF42705-8025
   Coding: 62954640
   VCID: 4ACD9F691C3DEC9A11F-801F
   Coding: 93070000
   VCID: 6B833AED730715924A9-803F
   VCID: 72BD2789542DC45A89F-8027
   Coding: E02400
   Coding: E02400
   VCID: 49CFA065193BE782185-801D
   VCID: 3431E1916EB98A6A5B3-8061
   Data carrier:
   VCID: 42DDB749240D34DAD9F-8017
   VCID: 3B23CAAD43E745129A9-806F
   Coding: 02A8
   VCID: 46D5AB59082508FAF57-8013
   VCID: 4CC199711649F2AA233-8019
   VCID: 372BD69D7FCF61727E1-8063
   VCID: 16753B191805787A457-8043
   Coding: 00101000
   VCID: 3333E28D6BB78D52429-8067
   Serial number: 00WGJJI
   Coding: 00010100
End----------(Elapsed Time: 02:39, VBatt start/end: 12.4V/12.3V)-----------
------------------------------0 Faults Found-------------------------------
A long cherished dream is to have carbon ceramic brakes. And through long work and dedication, I now have them.
dry test fit:
400mm x 38mm front discs from Audi RS6 4G 4K0615301L / 4K0615302L
Brembo calipers 8W0615107K and 8W0615108K in Mercedes AMG gold colour
370x32mm rear discs from Mercedes AMG
TRW rear calipers from Mercedes AMG
I'll need a 15mm spacer at the front (12mm is kissing the spokes)
And I'll need new front brake lines, since my TTS setup has an M12 banjo bolt and these calipers will need a more common M10.
https://imgur.com/a/0Y6Mcj7
Just some Pythagoras on the Haldex Gen 5 0CQ vs the 08E torque vectoring, and why you need a 55mm spacer on your cardan shaft.
I measured diagonal and offset, calculated the length.
Fun fact, the Porsche Macan came with a 2.0T inline-4 engine from the EA888 series, the CYN and DKN engines.
So you can have a Porsche engine cover on your VAG automobile, with part 95B103925H / 95B103925N
https://www.instagram.com/p/DJASMQcOFMo/
Some say it adds 50bhp to your car
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 8S0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 140725201720
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X_003_VW37.rod
Installed the sound actuator, it's a simple retrofit (relatively)
Parts
Module 8V0907159 / 5G0907159 / 3G0907159 / 4H0907159
Aktuator / speaker 4H0907601D
Bracket 3G1906468 (for Passat LHD)
4F0 973 706 connector 6 pin
4H0 973 702 A connector 2 pin
3C1971303 3C2971303 brackets for wiring
Wiring, not very difficult either
Positive is shared with i.e. the air quality sensor next to it, canbus is shared with i.e. engine.
Location is below the front parafane
Coding to have it in the individual driving profile:
Nice external infos:
https://mqb-blog.com/en/2021/06/14/sak/
https://github.com/jilleb/mqb-soundakto ... -firmwares
An older mod: automatic dimming passenger mirror
The RHD driver mirror is used as a passenger mirror in the LHD aplication
Parts:
- Mirror glass 3G0857522B
- Connector housing unknown PN (it came with my glass)
The wiring is very simple, just loop the driver mirror wiring to the passenger door, though the door, through the mirror and to the glass.
This will require a lot of work.
Coding is done in the passenger door module, byte 9 bit 0.
https://imgur.com/a/V6kLdjI
I never knew I could develop romantic feelings for brake discs, but you can.
The carbon ceramic brakes are installed along with the RS3 8V brake dust covers in both the front and rear (8V0615311B + 8V0615312B
I removed the RS3 brake coolers, to avoid them from shooting in stones, water and other crap that I don't want on my brakes.
It brakes very very well, the stopping power is amazing. I've hit ABS at 80kmh and I think I can probably go faster, but that would be unsafe I suppose.
I've also took the opportunity to retrofit the eBKV, the electronic brake booster als a replacement for the vacuum booster I had.
I figured it would be good to have the maximum available braking power at all times, and the big vacuum booster sometimes takes some time to 'reload'.
Parts needed for this:
Servo 3Q1614105BC (other 3Q1 will work as well)
Master brake cylinder 25mm 3Q1614019E
Brake lines 3Q1614739 / 3Q1614740 from MBC to ABS
26 pin 1S0973026A for main plug
4 pin 4D0971994 for sensor
4 pin 7L0973812 for connecting to ori brake light sensor connector
The wiring was very easy but troublesome, but it seems I simply had a faulty booster at first.
https://forums.ross-tech.com/index.php? ... ost-400930
Basic settings went through with ODIS and all is good now.
Check the link at te bottom for wiring diagrams.
ABS coding needed to change too for the eBKV:
So changes in byte 2 (eBKV) and byte 6 (disable vacuum sensor)
my old coding: 0FEC6B8FD1222371477D070560CB69F0D68BC4E2E00696759842508842A84A000000000012121212B835351919323200
my new coding: 0FEC7B8FD1223B71477D070560CB69F0DE8BDCE2E00696759842508842A84A000000000012121212B835351919323200
The ACC radar has a byte for eBKV too but I doubt it makes any difference.
So overall a nice retrofit, it finally works after a lot of headaches. And nice good braking. The pedal has a bit of a loose stroke at the initial press. I'll look into that further on.
Big thanks to ciclo and Slavik for helping me, with finding the problems and verifying the wiring with the electronic booster.
https://imgur.com/a/R7BeAfQ
current:
Sunday,08,June,2025,14:04:44:11868
www.Ross-Tech.com
Mileage: 199133km-123735mi   Repair Order:
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 23 2B 36 3C 42
          44 47 4B 52 5F 65 69 6C 6D A5 A9 BB BC CA D6 D7 8126 8127
VIN: WVWZZZ3CZJEiichel   Mileage: 199133km-123735miles
23-Brake Booster -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Readiness: 1110 0000
   Coding: 0014
   Coding: 0FEC7B8FD1223B71477D070560CB69F0DE8BDCE2E00696759842508842A84A000000000012121212B835351919323200
   Coding: 1F20200727
   ROD: N/A
   Air quality sensor:
   Coding: FFFFFF
   Coding: 0F4DFD
   Coding: 02005D
   Light switch:
   Alarm horn:
   Coding: 8A79267951
   Coding: 80000D
   Coding: 80000D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 8410
   Coding: 9309
   Serial number: 06071710802132 Dataset Number: SET_FPA_MOD 0001
   Coding: 0B0B00347F015900DB00027E9D0F00010001070000000000000000000000
   Shop #: WSC 31889 108 05361
   GVL: 015E3C1008000608C0FC80000006CC0010000000000200000030000000000000
   Generator:
   Coding: AF2B00
   Analog clock:
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 3Q0 909 059 AA    HW: 3Q0 909 059 A
   Component: EBKV          H06 0074
   Serial number: BPA085120421013
   Coding: 4103C500400000B5D65A6BAD000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 012121
   ROD: EV_BrakeBoostG2BoschVW48X_012.rod
   VCID: 76B51B993845D87AA57-8023
   Coding: 62954640
   Coding: 93070000
   Coding: E02400
   Coding: E02400
   Data carrier:
   Serial number: C855711JV003395 Dataset Number: V03935331AS 0001
4 Faults Found:
9616786 - Surroundings Camera Front
          B127C F0 [00001001] - Calibration Failed
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 199133 km
                    Date: 2025.06.08
                    Time: 14:01:01
9616787 - Surroundings Camera Rear
          B127D F0 [00001001] - Calibration Failed
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 199133 km
                    Date: 2025.06.08
                    Time: 14:01:01
9616788 - Surroundings Camera Left
          B127E F0 [00001001] - Calibration Failed
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 199133 km
                    Date: 2025.06.08
                    Time: 14:01:01
9616789 - Surroundings Camera Right
          B127F F0 [00001001] - Calibration Failed
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 199133 km
                    Date: 2025.06.08
                    Time: 14:01:01
   Coding: 02A8
   Coding: 00101000
   Coding: 00010100
End----(Elapsed Time: 02:41, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------4 Faults Found-------------------------------
Those brakes look overwhelming, a tremendous improvement... the braking improvement with that parts combination must be incredible. 8) Enjoy it!!
The setbacks experienced are part of daily learning, so there's always something positive to be found. 😁
hmm... in the image of the front wheel, it looks like you forgot the bolt caps at that moment... or are they capless for some special reason?
This was the first drive I made with the new brakes and the wheels have been off and on and off and on. I figured they might still need to come off again so I did not put on the caps just yet. I'm just very lazy in that regard, and it's a habit to torque down the bolts after a short drive too.
You should visit the Netherlands and have a drive in the car, just to try it yourself. We can ask Slavik to join too, I heard he is an incredible master of the BBQ.
Small pic dump, preparing some wiring for the illuminated door handles (powered by T20/3 F / T20/1 R + GND) and soft close locks (+30 and GND)
Also did some drilling to replace the lock latch with a powered one.
The locks are bought here: https://nl.aliexpress.com/item/1005005297635116.html
https://imgur.com/a/VZGGf3P
