Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.🤝
I think they are Anisotropic Magnetoresistive sensors (AMR). The 'diode' test I did with the multimeter indicates this.
:arrow: https://www.youtube.com/watch?v=LabJhzGuRI8
'Current flows only in one direction', like in a diode.
What do you think?
Speculatively, according to some readings made on the Indian forum, Team-BHP, they were factory-installed on some of the PQ25 models.
Coincidentally, the outer shape of the four speed sensors is more like a cricket bat than the golf club shape of the previous sensors. :lol:
The previous active Hall Effect speed sensors are very good sensors, seems these new ones for 6R are even better. Just ask the AI.
https://www.youtube.com/watch?v=THhjjnsgFlE
POLO 6R. New ABS speed sensors installed.
Despite the less-than-ideal weather conditions...
...I decided to install the new ABS speed sensors for the 6R in the middle of nowhere. I didn't take pictures; I already had enough to deal with between the rain and removing the wheel housing liners to check the available space to install the side PDC sensors for OPS 360º (12K) in another time.
Installing the new ABS sensors is straightforward: remove the wheels, the 5mm hex allen ABS speed sensor bolt (8Nm torque), and apply polyurea grease to the contact area. Gloves and a lot of brake cleaner was used during the process.
Autoscan.
Thursday,30,October,2025,13:58:23:32438
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: NEW ABS SPEED SENSORS OK!
Mileage: 95840km-59552mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 3C 44 55 5F 65 6C
VIN: WVWZZZ6RZDY0CICLO   Mileage: 95840km-59552miles
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000 CVN: 9A6217E3
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FD_004.rod
   VCID: 6A8D3FD44CF8023A307-803E
   VINID: 9E69EAAAA1A2A94A400030C808A8E303EA
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. User\6R0-907-37x-ESP82.lbl
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D30040D700
   Shop #: WSC 40308 002 104857
   VCID: 025D77745448FA7A987-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5038420709E9AFCF-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0812
   Revision: V0000000
   VCID: 3829D59C425460AA763-806C
   Revision: B9084001    Serial number: 2502 179190157
   Coding: 3CB02FBF48E12400B3380F317CEB9FD05AE8670F600D39D0200400030800
   Shop #: WSC 00046 123 12345
   VCID: 2D07F4C8BD16D502155-8078
   Component: RLHS 220816 0  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000A3
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331426800051 Dataset Number: 160039v____ 0010
   Coding: 0071157001
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372BD6A04FCA6FD27F9-8062
1 Fault Found:
12718592 - Databus
          U1121 00 [00001000] - Missing Message
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 29
                    Mileage: 95844 km
                    Date: 2025.10.30.
                    Time: 11:21:08
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP Dataset Number: v00305696R0 0001
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F542C38E23A107-801E
   Serial number: 3575HRB405N1C4LI7929
   Crash sensor for side airbag: passenger side:
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00255
   VCID: 47CBA6603F2A1F520F9-8012
   Revision: B9084001
   Coding: 002207
   VCID: 688945DC5274302A263-803C
   Revision: AA001001
   Coding: 0404000000000000000000
   Shop #: WSC 03607 002 104857
   ROD: EV_HighBeamAssisAU316_VW32.rod
   VCID: 2E05F3C4B090AE1A2CF-807A
   Component: IMMO          H04 0805
   Shop #: WSC 12345 123 12345
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 020100
   VCID: 2A0DFFD48CF8C23AF07-807E
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0519386082 Dataset Number: V03935258DF 0001
   Coding: 04011102
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C4886DF64582A55-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0519601132
   Coding: 040111
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA712279-807A
   Revision: --------    Serial number: -------------- Dataset Number: 6R0036v____ 0005
   Coding: 0112000001000000
   VCID: 77AB16A00F4AAFD2BF9-8022
   Component: MU-S-ND-ER    H41 0480
   Serial number: VWZAZ2W1480534 Dataset Number: V03935270BD 0001
   Coding: 02620001FF00000051110101C0890A801F0106C400A00100CF
   Shop #: WSC 34480 348 34480
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 25170CE8E566ED42DD5-8070
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 822 MM    HW: -----------
   Component: ECE AS 25/26  --- 2410
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_005.rod
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 4M0 980 556 A
   Component: RVC Compact   H19 0231
   Dataset Number: V03935314JY 0001
   Coding: 010402014600201F000060
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
   VCID: 392FD09879DE79A289D-806C
End----------(Elapsed Time: 02:06, VBatt start/end: 13.9V/13.9V)-----------
-------------------------------1 Fault Found-------------------------------
The original factory ABS sensors from 2012 once removed, cleaned, and measured.
I have three sets of these ABS sensors:
- the original factory sensors from 2012 (made in BE).
- some purchased from AliExpress in 2021 with the same part number as the originals (made in CN).
- the new 2025 model (made in BE).
Observations:
- All three sets work correctly on the 6R, but 'the multimeter readings' are completely different in each case.
- The ABS sensors purchased from AliExpress work exactly the same as the originals.
- The new ABS sensors: Since I'm a very sensitive guy..., with the new 2025 ABS sensors I've felt a slightly different braking behavior through the brake pedal. I think it's better (truly noticeable), but I don't want to jump to conclusions.
Plan C:
I'm afraid I'll have to remove the bumpers in the garage for my project 12K PDC OPS 360º... 😥😁
...the garage is like going out into outer space, it's all very dark.
Safe travels to all, and be careful, the road is dangerous no matter how many driver assistance systems your vehicle has.
Have a great weekend, everyone! ... without exception!
https://www.youtube.com/watch?v=UF4BrBmiSVQ
... I forgot to mention where to install the side PDC sensors (12K) in the bumpers once I checked the available room after partially removing the wheel housing liners.
For the rear bumper, there's ample room, but it's best to mount them at the same height —horizontal plane— as the other rear PDC sensors.
For the front bumper:
Image from CNK: https://catalog.polo.blue/6R0807217HGRU/ 🤗
In my case, 6R -Flintstones car-, braking system with the soles of the feet and with R-line suspension, the maximum height is approximately 51cm from the ground.
POLO 6R. 12K PDC project. OPS 360º. Latest tests. Before drilling the holes in the bumpers.
During the test:
-Everything works correctly. Everything, including automatic activation, BSD, RTA, etc... as before with 8K.
-The 1N4007 diode performs the PLA button trick. 🧙‍♂️
-The front PDC sensors are 4H0, the rear ones should be either 4H0 or 1S0 from the factory (I won't know until I remove them), the side ones seen previously in the image above are 5Q0.
-No additional faults. 8)
New ranking for Parking Aid:
1- 3K
2- 4K
3- 8K
4- 12K Area Hear 360º... 😁✌🥇
5- 12K Area View 360º
Plus all possible combinations of the previous ones with RVC Low/High, PLA, and other systems.
This week I will try to install the new 5Q0 PDC sensors in the bumpers and thus successfully conclude this project. When I'm done, I'll post the Autoscan and more details if there are any.
https://www.youtube.com/watch?v=ZeBlkz4CyKE&t=3s
Rear bumper.
Original factory rear PDC sensor reference number (2012).
The most up-to-date reference for these PDC sensor models is 1S0919275C.
Hole for rear side PDC sensor/holder (12K).
Those inner white marks are traces of the cut; they are not visible once the sensor holder is installed. The paint is perfect all around the 'circumference', it looks like it was painted rather than cut. Original tools = perfect holes.
New 5Q0 PDC sensor with holder installed vs. factory sensor holder removed.
The necessary cuts were made for a perfect fit and adhesion. The entire bumper can be lifted by simply holding the sensor holder, no additional adhesive is needed, although I applied a few small threads of hot glue along the edge of the sensor holder for a better seal.
This is what the installation of the 5Q0 PDC sensors looks like.
- The 5Q0 PDC sensors fit correctly into the 6R rear bumper in 'every way'.💎
The exterior appearance is similar to the divine, but I'm reserving the images for the end of the project.
- 2Q0 LCA radars installed and working like a charm. 🧙‍♂️
Note: The 12K process/project might be delayed. I've been talking to the masters of the universe, and they've told me my wife needs the 6R these days to carry out her 'important missions', so once again my irrelevant missions for the front bumper will be postponed until the weekend or next week.🤷‍♂️
However, it keeps raining, which is also important for what we all eat in the future...
-Saint Job-
or any other saint/character/divinity of patience.😄
...in the meantime, I'll upload some information.
POLO 6R. 2Q0 LCA radars installed.
All the information for programming, coding, and installation can be found in some previous posts.
Just a few screenshots, no photos, I installed them in the garage using a flashlight. The process is basically the same as for the 5Q0 radars.
They work very well, just like the 5Q0s, perhaps slightly better in terms of detection range, both for BSD and RTA, but nothing special.
I think they come pre-programmed with the BSD warning lights at a medium brightness level. I can't access the brightness adjustment menu, neither on the instrument panel nor in the infotainment system. I'll keep an eye on it, as I haven't tested them at night yet. The medium brightness level might not be sufficient for sunny locations, or at least not to my liking.
With the 5Q0 radars, which don't have a brightness adjustment menu, the brightness for the BSD warning lights is powerful.
VCDS Autoscan. Ross-Tech. No ROD file found.
Address 3C: Lane Change (J1086) Labels:. 2Qx-907-686-V2.clb
Part No SW: 2Q0 907 686 B HW: 2QD 907 686 A
Component: HRE3_Kl15_Mst H06 0150
Serial number: 00006273342269 Dataset Number: V03935359EX 0001
Coding: 529524A0
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: N/A
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2QD 907 685 A
Component: HRE3_Kl15_Slv H06 0150
Serial number: 00006273536997
No ASAM data for: "EV_HREntryHellaGen3Kl15" (VW25)
As of today, I am using the latest version, also for Beta versions.
Thursday,06,November,2025,10:49:22:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: 2Q0 LCA RADARS OK! PARK ASSIST 1/2 INSTALLED :)))
Mileage: 96030km-59670mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 96030km-59670miles
   Revision: --------
   Coding: 01
   Revision: V0000000
   Coding: 0228DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: 18BC32
   Coding: 18BC32
Address 10: Park/Steer Assist (J791)       Labels:. 5Q0-919-298.clb
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0480
   Revision: --------    Serial number: 39431521100017 Dataset Number: 2KC800t____ 0003
   Coding: 0031167001
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: N/A
   VCID: 3B23CA9073E24BB29B1-806E
No ASAM data for: "EV_EPHVA2CVW364GP00" (VW37 *)
1 Fault Found:
12718592 - ROD - Unknown Error Code
          - 00 [00001001]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 96036 km
                    Date: 2025.11.06.
                    Time: 10:45:47
   Coding: 00314D
   Coding: 140E01
   Revision: B9084001
   Coding: 002207
   Revision: AA001001
   Coding: 020100
   Coding: 529524A0
   ROD: N/A
   Coding: 11250
   Shop #: WSC 00788
   Data carrier:
End----------(Elapsed Time: 02:06, VBatt start/end: 14.0V/13.9V)-----------
UPD:
💎VCDS Updater: :arrow: https://forums.ross-tech.com/index.php? ... ost-381180
Works for both units (10, 3C). Thanks!
Suddenly, the NEW rear right PDC sensor 'G206' (original/genuine 5Q0) decided to fail without my permission.
Everything was fine since I installed it (diagnosis, operation), but these things usually happen just by thinking about it. 🤷‍♂️ :mrgreen:
I'll fix it tomorrow with a new one.🔨
More delays, I suppose with some luck I can finish the 12K project before Xmas.😅
UPD: Intriguing mystery.🔥🔥🔥
I replaced the 5Q0 right rear sensor (G206) with a new one, but the problem persists.
This G206 sensor is connected to the original factory wiring, not the wiring I made for side PDC sensors. The new wiring I made worked correctly during the general previous tests (with 1S0 sensors). viewtopic.php?p=609224#p609224
Something strange is going on here. I'll remove the rear bumper again and recheck the factory wiring and the entire installation.🔨
Since the 12K PDC control unit is second hand...🤔, I've performed several flashes and loaded various data sets for diagnostic testing, but everything remains the same no matter what compatibility checks I perform.🤭
I've ordered another 1K8...B 12K PDC unit, now I have to wait for it to arrive. Everything under control... 🤦‍♂️😁
While I wait for the arrival of other 'NEW' parts 😋 I've ordered for the fun 12K PDC project, I'll share some more information about the 2Q0 LCA radars.
After thoroughly testing the brightness of 'my' RED BSD warning lights, both day and night, I can confirm that they function correctly, even when the sun shines directly on the area of ​​the side mirrors where they are installed. 8)
As with the 5Q0 radars, it's not possible, as far as I can program, to view the BSD warning light brightness adjustment menu through the infotainment system or instrument cluster, I think the 2Q0 radars would need to be connected to an extended CAN bus instead of a powertrain CAN bus -Terminal 15- for this to be possible. 🤷‍♂️🤔
Since there is no menu to adjust the brightness of the BSD warning lights on the HMI screen or in MFA+ because it's not possible on PQ25, ​​a voltage regulator is not needed for the 5V BSD warning lights, as the voltage sent from the rear radars to the BSD warning lights remains at its original medium level setting.
However, unlike the 5Q0 radars, with the 2Q0 radars, it is possible to view the fully functional BSD and RTA menus in the infotainment system's vehicle settings.
BSD (BSM).
RTA.
With both the 5Q0 and 2Q0 radars, the activation menus for BSD and RTA are visible on the instrument cluster (MFD+), which is more useful for everyday/daily driving.
The 2Q0 LCA radars work just as well as the 5Q0 ones. Maybe the 2Q0 work a little better in terms of operational speed, but only noticeable for very, very, experienced people.
Data sets tested and 100% working:💎
-ODIS
V03935359EX 0001
-VCP
DB_03C_7100_2G0_MBX3_SK3260EUK0BA.flash
DB_03C_7100_2G0_MBX6_SK3260EUK0BA.flash
Remember that this installation is being done on a 'POLO 6R' PO25 from May 2012. 🤭
UPD:
After more than a month of use and enjoyment, I can only say that they work wonderfully. 🧙‍♂️
UPDATE: 💎💎
5Q0 radars + 6R BSD mirrors, etc. for sale at an affordable price.
:arrow: :arrow: :arrow: https://drive.google.com/drive/folders/ ... sp=sharing Work wonderfully. Codified, parameterized!
Contact me via PM if you're interested. Related: viewtopic.php?p=605611#p605611
I just need the new parts I ordered next week to arrive so I can start finishing this beautiful and fun multi-project and truly continue enjoying the results.
https://www.youtube.com/watch?v=BFetvsemGOY&t=251s
These past few days I've made several online purchases on different websites. In an AliExpress shipment/bag containing several orders, one of them was missing. I filed a complaint, but it's pointless because AliExpress says the shipment/bag with the multiple orders was delivered and that I haven't provided conclusive proof.
Please, could someone from the world of normal mortals explain to me how I can record a video or take a picture of something I haven't received?
Missing item:
For better understanding, something like this happened to me:
Where is my finger?😄
This is the explanatory image I sent to AliExpress customer service without any positive results.
Be careful with online shopping 2025... the world order is completely broken. 😁
https://www.youtube.com/watch?v=QSQwFqUHNK4
When life gives you lemons...
POLO 6R. 12K PDC project. OPS 360º. RR G206 PDC sensor faulty. Intriguing mystery solved!🧙‍♂️
Needless to say, what follows is my personal experience; each vehicle has its own particularities/control units/etc...
I checked the entire PDC electrical system, factory wiring, adapter, and the wiring I made myself. Everything was perfect, as you can imagine.
When I bought several sets of 5Q02919275B PDC sensors, I received a set with part number 34D919275A. I asked the seller, and he told me they were the same. I read in several places that some people, but not all, had problems with these 34D sensors from VW China, but the seller told me I could install them without any issues...
Since I have PDC sensors of almost every part number, I performed multiple combinations/tests to detect which sensor was faulty, arriving at the following conclusion/solution.
With the 4H0, 3C0, 1S0, and 5Q0 sensors, there are no problems/'diagnostic faults', regardless of their origin. The most up-to-date ones are the 1S0919275C (usually for PQ) and the 5Q0919275B (for MQB and also PQ).
For example, the Amarok (PQ25) comes from the factory with 5Q0 front sensors and 1S0 rear sensors.
My 6R will be the opposite, plus 5Q0 side PDC sensors for my 12K project (F=1S0C, R=5Q0B, FS=5Q0919297B, RS=5Q0919275B).
Note: I'm not saying that the 34D 02% sensors are not well manufactured; obviously, they will work correctly with 5QA or 5Q0? units.
That's all, folks! :lol:
Now it's possible that my 12K multi-project will finally move forward/successfully this week...https://www.youtube.com/watch?v=Io6zfPVWC10
Front bumper.
Rear bumper :arrow: viewtopic.php?p=609232#p609232
Installation complete, I'm in the testing phase, so far I can only say that everything related to this multi-project is much better than before, significant and very pleasant improvements.😊
These days I will be uploading more information about the 12K project and the new OSRAM LED lamps (SCLs, F Fog, 'etc').
...some purchases of parts I made during 11.11 (Ali, eBay) during this multi-project, which I had not yet shown and which are in the testing phase.
Surely some of you have already installed these magnificent LED lamps to replace the obsolete HID xenon lamps.
I chose these (Carlitek) 'for testing' because of their affordable price and because, mysteriously, they're almost identical (same components) to those manufactured by OSRAM. The build quality is very good.
I'm also waiting to receive the OSRAM ones (they cost triple).
For those of you who haven't done so yet, you can get great discounts on Black Friday.
The following images are not a product promotion, I am simply showing you some pictures that you should be aware of, as there are many models of this type of LED lamp that replace xenon lamp.
1:1
In the first instance, the improvement is very satisfactory. No diagnostic faults.
The xenon lamps are DEAD!
On the other hand, another 12K PDC unit with the original 1K8 B firmware. Everything is exactly the same as the 5Q0.
It's convenient for me to have two since I have all the firmware files (B, D, E) and Datasets, I'll have one installed and the other for test bench.🧙‍♂️
https://www.youtube.com/watch?v=UxzR8-pJOoM
POLO 6R. 12K PDC project. OPS 360º. PDC sensors installation. How they look on a 6R. Result!
Let's do a 360° turn to see the result.😊
Diagnosis.
The priority 6 fault inherent to the PQ25 platform(*Exception: :arrow: 1S2 909 144 P + 1KD 919 472 A + 6R0 959 654) when installing the 1K8/1KD control units, which does not affect its operation, remains regardless of which PDC unit/firmware (B,D,E) or data sets are used.
Since the intention is OPS 360º and not PLA, all datasets are compatible and interchangeable between firmwares. :lol:
VCDS Autoscan.
Thursday,20,November,2025,13:17:56:32438
Data version: 20251020 DS365.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: 12K PDC OPS 360º OK!!
Mileage: 96360km-59875mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 96360km-59875miles
   Revision: --------
   Coding: 01
   Revision: V0000000
   Coding: 0228DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: 18BC32
   Coding: 18BC32
   Revision: --------    Serial number: 39491531301709 Dataset Number: 2KC800t____ 0003
   Coding: 0031167001
   ROD: N/A
1 Fault Found:
          - 00 [00001001]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 52
                    Mileage: 96361 km
                    Date: 2025.11.20.
                    Time: 13:14:26
   Coding: 00314D
   Coding: 140E01
   Revision: B9084001
   Coding: 002207
   Revision: AA001001
   Coding: 020100
   Coding: 529524A0
   ROD: N/A
   Coding: 11250
   Shop #: WSC 00788
   Data carrier:
With 12 PDC sensors, everything works wonderfully, better than with 8 PDC sensors (obviously), but I mainly think that's due to the installation of the 5Q0 PDC sensors on the back... No ghost detections or anything like that.
The sensitivity of the MQB PDC system on a PQ.💎🧙‍♂️
https://www.youtube.com/watch?v=mcvLgyqg-UU&t=64s
UPD: After a couple of days of using and enjoying it, I'm super happy with this crazy idea I had. It's great to see how all these perimeter warning lines move in the OPS as you move. No inaccuracies or false detections, super accurate!👌
https://www.youtube.com/watch?v=mcvLgyqg-UU&t=230s
POLO 6R. LED fog light bulb. LED bulb for SCLs in bi-xenon headlights. D3S LED bulb for bi-xenon headlights. WHITE!💘
Previous information:
-viewtopic.php?p=609152#p609152
-viewtopic.php?p=609327#p609327
Note: There's no point in taking pictures directly of any light source that's ON. I don't do that. Any 'normal' image capture lens will saturate, only take angled images to observe the amount of light, color, or pattern projected onto a surface.
OSRAM Speed ​​H7 LED bulbs for Static Cornering Lights (SCLs). Approved!
- Warm white color. For reference, whiter than OSRAM's Cool Blue Intense Xenarc xenon bulbs.
'Soft light', gentle, not bright, perfect for performing their function at corners, roundabouts, intersections, or turns as SCLs without dazzling other drivers.
At the moment I have only taken this image to see how it looks installed.
Static Cornering Light Reflector inside the 6R Bixenon headlight.
8)
OSRAM EASY H8 LED bulbs for fog lights.
Exactly the same as the OSRAM Speed ​​bulbs. Colour, etc...
I can't think of any 'scientific' reason why these led bulbs are only for off-road use and aren't street legal. There are fog lights on modern vehicles (2025) that are much more powerful and brighter than these LED lamps.🤷‍♂️😁
Many people with poor judgment might think they're insufficient as fog lights, but fog lights aren't meant to illuminate the road to infinity and beyond, quite the opposite, they're meant to widen your field of vision in the immediate area, since in fog you'd be blinded by your own fog lights.🤭
UPD: I don't like the look of these OSRAM H8 LED bulbs and I've returned them. I'm going to install other H8 LED bulbs that are nicer. They're also 'OFF-ROAD' LED bulbs with perfect patterns designed to fit reflector-type fog lights so as not to dazzle other off-road drivers. The appearance is a priority for me since I will only use them off-road, so at least they are pretty. From X-STORM, already tested, 6+6 LEDs CSP. (storm ⚡🤭)
D3S LED bulb for bi-xenon headlights.🤍
Brilliant white!
On par with or better than the Original Matrix LED headlights on our Golf 7.5.
The beam pattern is perfect. No dark areas/spots within the illuminated area. The illuminated area is well defined, pure white. They do not dazzle oncoming traffic.
Highly recommended!!!
Only these images for now.
I'm totally impressed with how well they work... 😮
UPD: After a couple of days of use and testing on all kinds of roads, in all kinds of traffic, and in various weather conditions (except snow), I'm speechless at how well these Carlitek D3S LED bulbs perform. HBA continues to work just as well.
My wife asks me what on earth I've done to the car, saying in general terms that it's running great now...🤭
https://www.youtube.com/watch?v=Xd0Nsl6wleE&t=238s
Although it's not necessary, I'm going to try to improve the headlight turn signals... as you all know, they're a bit weak on the 6R due to its location on the headlight.
Headlight Adjustment.
Slightly separated from the wall to show you the patterns.
This place is gloomy and dismal 😄, but it's ideal for making this adjustment.
High Beam, 10 m.
8)
I've used this adjustment for years and it's always worked well. It also works perfectly with more advanced headlights, although it's always advisable to perform an adjustment with more advanced devices.
It's important to know the prerequisites before adjusting the headlights (AI, erWin, etc.). That is, correct tire pressure, full or half-full fuel tank, removing the family from the car, including pets such as elephants, giraffes, dinosaurs, etc., and balancing the suspension (manually, or automatically - drive forwards and backwards those 10 meters a couple of times).
Different regulations apply depending on the location for even a small percentage of inclination angle, according to ECE and SAE standards. This must be taken into account when adjusting headlights (AI, erWin, etc.).
For now, I'll continue testing the Carlitek D3S LED lamps, which work amazingly well, and when I receive the LED lamps for the bi-xenon headlight turn signals with 3 times more lumens than the factory ones, I'll install these OSRAM D3S LED lamps, since in any case, it's necessary to remove the headlights to install any of these lamps (erWin).
UPD:
💎 Excellent in every way, which together with the VANSSI LED lamps for the turn signals viewtopic.php?p=609409#p609409, elevate the 6R Bi-xenon/Bi-LED headlights to a higher level.🧙‍♂️
https://www.youtube.com/watch?v=wU5xRUkUVFM
Locked
