strange idle behaviour - ***SOLVED***
Ajit_mk2_16v
Hi all
My 1999 1.4 16v polo has been giving me problems!
My car used to idle at 800rpm at standstill, now this has increased to 1000rpm.
When i move away the revs do not return to rest when coming to a standstill. They remain around 1000-1500 rpm
Upon start the revs hit 3000rpm and go between 2000 and 3000rpm and do not settle down to normal. Unless I stop the car and restart when they idle at 1000rpm....
Could it be the temperature sensor ? can someone help!!!! - thanks
bloomfield_5
Throttle valve???
From the sound of it, I think it might be the throttle valve.
Sometimes the throttle valve gets all clogged up with crap and stuff. This makes it stick and not open and shut properly. Try taking it off and cleaning it out with some carb cleaner.
Ajit_mk2_16v
Re: Throttle valve???
Does the ECU need to be reset as well?bloomfield_5 wrote:From the sound of it, I think it might be the throttle valve.
bloomfield_5
No
nope it shouldn't need to be. Because your not replacing it with a new one. If you haven't got an engine warning light on then just cleaning it out shouldn't effect the ecu, and it will stop it sticking.
david burton
mine does this, or used to. temp sender doesn't fix it. i tried cleaning the butterfly valve and so on, but nothing helped. ecu resets sometimes helped, but now the car seems fine, I think it might just have needed a bit of adaptation to my cleaning.
if you put the engine under load - i.e handbrake on, and let off the clutch slightly, so the revs drop - does it stay at 1000rpm? if so, it's identical to mine. sometimes putting the fan on full returns the revs to normal!
noone else seems to be able to help me tho
going to leave it, putting it down to "one of those things" as it doesn't happen all the time.
BenMMellor
Re: No
I'd argue that this is one of the firs thtings to do as its cheap and free ! You won;t harm the engine doing it..bloomfield_5 wrote:nope it shouldn't need to be. Because your not replacing it with a new one. If you haven't got an engine warning light on then just cleaning it out shouldn't effect the ecu, and it will stop it sticking.
I had similar issues with my 16v. When it was in having the cambelt changed the battery was off for an hr and caused an ECU clear and reset.
No more idlin problems..
Ajit_mk2_16v
bloomfield_5
sorry
sorry my mistake.
I think I was wrong too. If you have had the battery disconnected or had any faults then resetting the ecu probably would solve it.
If that isn't the problem then you could always try the throttle valve.
Ajit_mk2_16v
Ajit_mk2_16v
an update
Well,
I took the car to my local independent garage.
I got him to connect his hand held tool to the cars on board computer.
One fault code was displayed 01250 - Injectator Cylinder 2 o/c or s/c intermittent fault.
The garage wasn't concerned about this and puts it down to an electrical error so he reset the ECU and to my surpise the car was running fine! normal revs and in fact so far its running smoother than normal.
I need to go back next weekend to get the logs read again so see if the fault returns, but it looks like an ECU reset was the way to go!
BenMMellor
Re: an update
which is what will happen if you disconnect the battery for 20 mins folks...Ajit_mk2_16v wrote: I need to go back next weekend to get the logs read again so see if the fault returns, but it looks like an ECU reset was the way to go!
Ajit_mk2_16v
Re: an update
Agreed! its the way forward!!!!BenMMellor wrote:which is what will happen if you disconnect the battery for 20 mins folks...Ajit_mk2_16v wrote: I need to go back next weekend to get the logs read again so see if the fault returns, but it looks like an ECU reset was the way to go!So use this as the first action.
