how to reset service interval
polo2k
if youve ever had a service done at a garage apart from vw or even done one your self then you will have a new code on your milage display every time you start the car. it will read something like this "IN01" or "IN02" or somthing like that. to remove this follow these simple steps.
this should work on any vw with a digital odometer (6n2 mk5 verified and 6n mk4 soloud be the same, also applys to golf 3/4)
1. with the key out of the ign find and press the reset button (hold down)
2. turn the ign on (warning lights come on) wait about 10-15 sec till most or the lights are off ( still pushing button)
3. turn ign off (button still pressed) and remove the key
4. release button
5. see if interval has stopped, if not then follow 1-4 again
have fun
4. release button
have fun
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
can you help me with mine,
when i do it on mine after step 4 it just says OEL and if i press the reset button its changes to IN01 and if i press it again it it goes to IN02 then if i press it again it goes back to OEL and so on. this goes away when i switch the ign on again.
you say wait till all the lights go off but on mine the oil, battery and handbrake just stay on with ignition
this is wierd because my polo has always been serviced at veedub
plz hlp
plz hlp
- bstardchild
- Moderator
Gareth_GT_Hatch
- Platinum Member
reset
Lupo 1998>
Polo 1999-02
Polo Classic/Estate 1999-02
OIL-Oil service
Press and hold button (A) (Located on speedometer below LCD display)
Switch ignition ON
Keep button (A) depressed until "---" appears in display
Release button (A)
Switch ignition OFF
INSP- Inspection service
Switch ignition ON
Release button (A)
Switch ignition OFF
If required clear the "OIL" indicator from the display as previously described
Polo 1999-02
OIL-Oil service
Switch ignition ON
Release button (A)
Switch ignition OFF
Switch ignition ON
Release button (A)
Switch ignition OFF
Just to let everyone know, I have used this for my wifes old Arosa and it work great, however, her new car is a Leon. if you want to reset the service oil on this you have to add a further step to the instructions:
press and hold the button
switch on ignition
keep button depressed for 15 seconds
start engine (with button still depressed)
stop engine and remove key
release button.
Hope this helps
switch on ignition
release button.
Hope this helps
