Bulbs...
Bulbs...
What do you guys think about bulbs? Is it worth it changing to a bulb like this?http://www.powerbulbs.com/products/prod ... bv&type=H7
Would it give better light? I had the older type of this bulb and it was OK
Babe RuthLess
Wow, 2k could I have more info? I would love to fit the lights and I will have the washer jets too. What about the levelling system, coz it will only have the manual one... And do you replace the reflectors with lenses?
I would love to do this so really appreciate more info on how to get them, prices etc?
The main bulb, I THINK, is H1 Babe RuthLess
Position lights, not sure...
polo2k
theres more info in the diy forum and the vag parts forum (posty title guenee pigs reqd) and its just the same as replacing a bulb exept you have to fit a box at the same time and drill 1 hole but theres no permanant mods so its all removeable without a trace exept for the rear cover on the headlight which is cheep to replace
as for the washers i dont have them and havnt had a problem yet (car jet washed once a weak) and the adjusters i dont have either if i get flashed twice in a short period of time i lower the beam
Ok anyone, do you have a pic of a 9N Polo with the front bumper off? I need to see behind there so I can confirm there is space to mount the ballasts before I buy the kit.
Also, does the dipped beam stay on when you flash the main beam? (As above) Just normal halogen lights I mean on any 9N.
Thanks peeps
Thanks peeps
