[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Brake fluid - UK-POLOS.NET - THE VW Polo Forum
I believe not all fluids can be used with rubber lines - plus, racing fluid may not overheat very quickly but it may attract water more quickly. Which would not be a problem if you replace it before every race. It's best to get proper info on which fluid is right for you - I'm guessing it'll be 5.1
