Nelson finds another OEM mod :D
Petrified
Sponsor
Post by Petrified »
Uk_Polo_GTI wrote:whats etka?
As far as I know it's the software that shows a catalogue of all the vw/audi parts.
**Edited by Admin**
James.
Babe RuthLess
Post by Babe RuthLess »
I may be wrong, but I think ETKA stands for Elektronisch Teile Katalog or Electronic Parts Catalog. Or something.
Anyways Petrified has the answer.
It's the software that VW dealers check when you ask for a part over the counter. It gives exploded views of all systems in a VW car, showing the parts and their respective numbers.
Cool stuff. 8)
dutchpolo
Post by dutchpolo »
We have the thing on top of the dash! In our 2003 1.4 Polo Highline!
Willem
Nelson_Wilbury
Moderator
Post by Nelson_Wilbury »
Petrified wrote:nice one.
:wink:
Oh, and apparently if you have climatic air con you can swap out the front panel for the climatronic. Might be worth seeing how much that would cost.
James.
I have since found that to get Climatic you also need a new loom which is £200 + VAT so your looking at £500 to get Climatatic fitted aftermarket.
Neil
Uk_Polo_GTI
1st Stage Warning
Post by Uk_Polo_GTI »
damn :evil: all the labour involed aswell i should of got it factory fitted for only 300 damn well anoyed :x
Nelson_Wilbury
Moderator
FAO Petrified.
To get a lockable glovebox your looking at £30 + VAT. But remember a locking barrel will need to be ordered to key number (will take about 7 working days)
Neil
Petrified
Sponsor
Post by Petrified »
Thanks mate!
This is something I will be doing ! :D
James.
Babe RuthLess
Hi...
Does anyone have the part nos. for the lockable glovebox mod?
I tried my luck at my local dealers but they claimed there was no such thing available.
I found out, however, that a lockable glovebox is fitted to export cars (damn I hate that, VW cut costs on its second-biggest market but the cars that go to the caribbean or mexico or wherever are fully specc'd!!).
So the part numbers would probably allow me to order whatever I need from the factory.
Thanks in advance!
toXXin
Moderator
Post by toXXin »
Has anyone fitted a sunglass holder to their 9N yet?
The reason I ask is because I tried fitting one to my 6L Ibiza (the new one based on the 9N) and the supplied screw pushed my my roof! To say I wasn't pleased is an understatement.
I've asked a dent specialist to remove and they said they can't, so it looks like I'm going to have to get the lump removed at a bodyshop :(
Just a word of warning if you haven't!
6N or 6N facelift owners, if you want a sunglass holder for less than VW price, PM me :)
Nelson_Wilbury
Moderator
toXXin wrote:Has anyone fitted a sunglass holder to their 9N yet?
Yeah, I did the sunglasses mod a while back I remember Speedlaws write-up saying to use original screws, looks like it was good advice!! :shock:
polo2k
Post by polo2k »
thats normally the case as long as the thickness of the new part isnt much more and the original screw can get a good grip then leave it! same applys for wheel nuts when fitting alloys as long as the cone angle is the same or the spheric diameter.
before you try a body shop you might as well give it a try at repairing it your self cos you cant really loos so you might as well learn a little dent removal and if you mess it up then it doesnt cost you aany more
see my sig too
Babe RuthLess
@toXXin
I fitted the sunglass holder to my 9N, no problems whatsoever.
Turns out the screws provided with the holder were actually shorter than the ones in the grab handle, so I used them. But that's by no means a rule, so whoever wants to do this mod should check the screws first!
@polo2k
Your're right...
Nelson_Wilbury
Moderator
Babe RuthLess wrote:Hi...
Thanks in advance!
It annoys the hell out of me when so called 'Parts advisors' can't even find the simplest parts on ETKA :evil:
Go to another dealership because you can definately get a lockable glovebox, don't take no for an answer!! :wink:
I would give you a part no. but there are about 4 chassis breaks on the glovebox already :shock:
Babe RuthLess
Thanks Nelson, I'll bug them tomorrow morning! :D :twisted:
leonsmith
Post by leonsmith »
Babe RuthLess wrote: I fitted the sunglass holder to my 9N, no problems whatsoever.
@polo2k
Fitted a sunglasses holder to my 9N last night and found the same - screws provided were actually shorter than those on the original handle so I used them instead.
Nice little mod that for £12.....
