The alternator belt pulley (on the crankshaft) needs to come off, so the water pump and cambelt can be changed before putting the head back on. Unfortunately some genius decided allen bolts would be the best bet for it, and it should be hidden behind a panel with very little clearance.
One of them has undone ok, the other three are stuck, tight enough that having it in gear to brace against made the car rock back and forth*. Two of them are stuck too tight for my short keys to apply enough torque to break the rust, threadlock etc. The third suggests that even having a better set of keys wouldnt be enough as its rounded off slightly and the proper size one cant quite get a grip any more (the very next largest one i can find is only *just* too big).
Blasted them all with WD40 etc but no luck.
Haven't yet tried the heating-with-a-ciggie-lighter trick though.
Got any tips, clues, methods? Remember I need to get it back on again! (if its likely i'll need to find new bolts, then where might they be sold?
That, or some other way to swap the belt over and free up the waterpump without having to take this thing off? (the inner cambelt cover is in the way apparently, and removing the pulley frees it)
Just one thing after enough eh!
* (though, maybe 4th would be a better idea than 1st)
