brake pedle sensor
dubpolo
Sponsor
brake pedle sensor
Post by dubpolo »
hi guys! why is it, when you need to travle somewhere in your car it brakes! anyway, on friday morning i noticed that my brake lights where not working. so i checked my bulbs, they where ok... so i looked for a fuse (their aint any) so i got my mate to stand behind my car and have a look if they are working, sometimes was the awnser. so... brake pedle sensor must be bust, down to VW and bought a new one, fitted it and now the bloody brake lights won't go off! :shock: do you need to get the sensor programed with VAG COM? please help!
ModifiedMadness
Sponsor
Post by ModifiedMadness »
Can't help you mate but I can sympathise with you, just before I picked my GTi up a water hose went on my car (which was the p/x against the Polo) not just any hose though possibly the hardest one to change so I ended up £86.90 lighter just so I could get the Polo. Sods law I guess
Si_GTi
Moderator
Post by Si_GTi »
inder
Post by inder »
Perhaps you put it in wrong, twist it in with the switch bit fully extended (looks too long, but will adjust to fit when you place in)
in fact:
Brake pedal - Assembly overview
Adjusting brake light switch
Remove brake light switch to adjust.
‒ Pull connector off brake light switch.
‒ Remove brake light switch by turning to left through 45° or 90°(depending on switch).
Installation of former brake light switch version (with corners)
http://img14.imageshack.us/img14/4396/n4603103zt.png
‒ Before installing, pull out plunger completely.
‒ Press down brake pedal as far as possible by hand.
‒ → Guide switch through fitting hole and secure by turning 90°to right.
‒ Release brake pedal.
‒ Fit brake light switch connector.
‒ Check function of brake switch.
After adjusting brake light switch, ensure the brake pedal is in the end stop position (released position).
Installation of new brake light switch version (round)
http://img14.imageshack.us/img14/6497/n0105322ey.png
‒ → Guide switch through fitting hole, press against pedal and secure by turning 45°to right.
‒ Brake pedal must remain at rest position (not depressed).
‒ Check function of brake light.
:wink:
dubpolo
Sponsor
Post by dubpolo »
Thanks for your help guys! It was my fault, I aint put it in right. Anyway for once my dealer was really helpful! He talked me threw the installation and pointed out that the sensor had to be activated in the right place (when you turn it threw 90 degrees you are selling the limits! because they use the same sensors on all models) and he said I had buggered the sensor and gave me a new one free! Get in!
inder
Post by inder »
No problem. Nice guy for doing that, glad you have it sorted now 8)
