Trying again in slightly cut down form in the appropriate section
Come on, give us a clue, someone must be able to remember how their own carrying out of the procedure went, i know there's at least three people i can name on here who have done gearbox swaps!
Cheers in advance...
ok, before i even touch the nuts again, i want to get this fully cleared up as its a bit murky.
Haynes says:
* Crack the seal on the hub nut, with some welly, and loosen a bit (same as taking off wheel bolts seems the idea)
* Loosen wheel bolts
* Jack it, remove bolts and wheel
* Undo inner CV joints at gearbox (piece of cake, done it before)
* Support shaft bit of CVs on axle stands (ok, a bit odd, but at least i have a couple spares i can use for this)
* Remove hub nut and washer
* Wheels on full (left? right?) lock
* "Tap the driveshaft from the splined hub using a soft head mallet" - i assume it projects through the brake assembly to the outer side of the disc and can be shifted using the mallet and a tap ... unless it goes far enough that the mallet alone will do it?
* Refitting is reverse of removal (doesn't say how you re-seat it firmly in the hub - seeing as it had to be tapped out - hmm)
* BUT, a NEW hub nut will be required. (where the hell will i get one of those? gsf, for a premium? presumably a new washer as well) --- Which is fair enough, as it's under more torque than the headbolts are!
People on here so far as i remember have said
1. Labour the hubnuts off
2. Remove shafts
3. Profit
BUT ---
# Omicron says something about a flange ...
# Dubpolo and others say about the nut shearing ...
# and, an independent contact warns about the CVs coming to pieces once the support of the driveshaft is removed.
So............... a lowdown is needed I suppose. Anything haynes may have missed - they aint exactly reliable, but all I've got
i've tried hefting on it with all my might, two handed fingers interlocked pulling upwards as prescribed...... nothing..... tried wailing away on the breaker with a big ass lump hammer (impact socket on).. nothing. obviously a pipe and maybe some heat are needed, which will probably require some ingenuity to secure both.
I wonder, would my wheel nut wrench be any cop for this? It has an extendible handle that comes out to at least 2ft, maybe more, a 1/2" square drive, and is a bit more solid at the business end. Prob is, the extendible handle means it rotates in wierd ways sometimes!
