Just had my 6n2 lowered
BLK_POLO
Post by BLK_POLO »
I just got my 6n2 lowered on eibach sportlines and the steering wheel isn't aligned with the wheels, do i just need my camber sorted and wheels aligned to sort this out.
I just phoned a local garage and they said that on new polos you cant adjust the camber is this correct.
mikegti
Post by mikegti »
Try taking it to a garage that can do the 4 wheel laser alignment, that should do the trick!
dubpolo
Sponsor
Post by dubpolo »
camber on the front is adjustable but on the back its not
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
most likely your tracking
-Ben-
Ross16v
Post by Ross16v »
I have the same problem as this the garage have told me the car cannot be tracked until the camber on the front wheels is sorted is this s**t???
how can i sort the camber???
Cheers Ross
Ross16v
Post by Ross16v »
I have now sorted it. on the Fk coilovers there are two bolts on the bottom of the suspension leg, if you losen these you can adjust the camber then tighten them back up only took 5mins!!!
OMEGASUPR3ME
Post by OMEGASUPR3ME »
hey ross can u do a how to guide of that coz i have fk ones aswell and think i need to adjust my cambers. thanks
