Hi
I have recently removed mine, its a straight forward job!
1. Remove standard vw audio kit (with removal keys);
2. Remove cup holder and blank (access from din area);
3. Remove top tray or cubby box (pull up towards the back);
4. Remove plastic trim around temperature controls;
5. Remove buttons (if required);
6. You now have access to all the star screws, which are as follows:
a) 2 x top (cubby area)
b) 2 x centre (double din area)
c) 2 x behind cup holder (1)/blank(1)
d) 2 x bottom (behind the plastic trim - temp controls)
Hope this helps, its not as bad as you imagine!
Thanks to JillWilson, without her help none of this would be possible!
