It's already primed and ready to spraypaint
Looks sweet doesn't it
Jep, memory red Pearl it is! As far as I know I'm the only person in a memory red pearl 6N in Holland who's done something to his ridehelios1 wrote:yeah man looks great!
Your car a 1.3L from 1995? Memory red pearl paint?
Same as mine!
What I want to do with the inlet:helios1 wrote:Good stuff you crazy dutch bastard!
How do you plan on widening the in;et manifold? wouldn't it be easier to make a wider one?
What else you planning on doing to it apart from increaseing inlet pipe diameter?
every noob can do this mod, it's really simple. Just took me 10 minutes to install! Just take of you airfilter, screw of your old pressure regulator (3 Torx 15 screws, and watch out your old pressure regulator doesn't pop-off, cause there's a lil' spring underneith) put on the new regulator, screw it on again, adjust your pressure as wanted, put your airfilterback on, start your engine, and take it for a spin.helios1 wrote:where'd you get the fuel pressure regulator? Looks pretty simple, how easy was it to install?
I think your talkin' 'bout this 6N?:jezmk4 wrote:Hello Jarno
Do you know of a another dutch (i think?) polo owner
with a 6N the same colour as you, with Borbet T alloy wheels that are colour coded?
