You can see the rubber in the grooves!!!
This was really getting my back up so i thought about toothed pullies, luck would have it that i had already had a PSD keywayed shaft fitted to my eaton and a quick call to PSD and a drive down there gained me a 58mm toothed pulley for a G40 charger, a sleeve was needed to fit the pulley to the eaton shaft but with an engineering company 2 mins from my work this wasn't a problem
I had to remove and borrow robs toothed belt crank and alternator pullies (cheers rob), fit them up and work out how far the eaton toothed pulley would need to sit and have the sleeve and pulley machined to suit and an extra larger key made for the keyway. Anyway the end result>
Back
Front
Toothed eaton pulley
The pullies line up lovely
Hopefully the belt will be okay as the charger is sitting a little pissed (arse end sitting slightly further towards the front of the car than it should making the belt want to ride off of the pulley as it turns
I've not given my car a proper blast yet and probably wont do until after the rolling road tomorrow (he says knowing that the temptation to race the lotus on the way may be to much). I'm just happy in the knoweledge that i will not get anymore belt slip
