Leaks
bigandygal
Leaks
Post by bigandygal »
My polo seems to be leaking either around the rear passanger window or door. It is obviously the seals but has this happened to anyone else and what has been done about it??
Does VW replace them or what.
carmadaaron
Post by carmadaaron »
on a 5dr i take it?
yeah ive got tat too, esp after a car wash
duno if its a seal problem :?
SiDaBa
Sponsor
Post by SiDaBa »
Do a search in this forum!! It's a problem i haven't heard for a couple of years but an existant problem, believe the posts also found answers to the leaks :)
andrewg450
Post by andrewg450 »
It would be worth checking if its the rear wash wipe spray that is leaking as opposed to the door seal. This happened to me and is easily fixed.
Hope this helps,
SiDaBa
Sponsor
Post by SiDaBa »
andrewg450 wrote:It would be worth checking if its the rear wash wipe spray that is leaking as opposed to the door seal. This happened to me and is easily fixed.
Hope this helps,
Is that not solely in the boot? :?
Andy Beard
Post by Andy Beard »
yeah mine leaks a bit. its the offside wingmirror
when i open my passenger window i can see the seal is a bit crooked just where the wingmirror plate is
algenon_iii
Post by algenon_iii »
Ok this is stating the bleedin obvious 8) but make sure your rear windows are fully wound up. In the past (not noticed it recently) they've wound down a mm or two - just enough to let water in.
bigandygal
ye i hav obv made sure they are fully up and they are!!! but they still leak :-(
