It looks like my thermostat has failed, luckily in the open position.
Is it easy to change? Whats the easiest way to drain the coolant? When replacing, does it need a new gasket?
So many questions, but too tight to buy a workshop manual.
Thanks in anticipation.
Thermostat
mike-snapper
I had something simila. My water pump failed and caused the theromstat to Over extend punching the thermostat housing out locking the thermo closed, yes I bent the head.
Water and coolant can be removed by undooing the radiator bottom hose and filling a bucket. The thermosts housing in my 6n is plastic and had a rubber seal but some gasget sealant might be a good idea too.
