Roof aerial
Scorpio1
Roof aerial
Post by Scorpio1 »
Does anyone know where I can get a shorter aerial as my garage is low and I don't want to keep taking it off and putting it back!
I know my reception will suffer, but not too fussed as I listen to CD'S 90% of the time anyway.
I have asked around and no-one seems to know for the new Polo :(
polo2k
Post by polo2k »
try honda s 2000 or halfords and ask for a bee sting antenna
polo2k
Post by polo2k »
or fit coil overs :D good reason to be slammed inho :P
Scorpio1
Post by Scorpio1 »
:D I already have about 5 mods planned, so I'll leave the suspension, well for a while anyways! :lol:
I had a look in Halfords but they don't look any smaller, might try the Honda route though...
Josh_PoloGTi
Site Admin
Drives: BMW E85 Z4 3.0i
Post by Josh_PoloGTi »
I must have told this to about a million people now...
  • Unscrew your antenna (VW Bee-Sting Plastic Type only)
    See the top plastic cap over the end of the helically wound antenna? Heat this up with a hairdryer.
    Pull this small plastic cap off when it is hot enough.
    Get some wire cutters and cut the antenna (with the wire wrapped round it) to the desired length.
    Push the end cap back on (if it's loose, put a dab of glue inside it first).
Booyah... One shortened Bee-Sting antenna. Cost: Nothing
Hope this helps!
Be carefull with hot stuff, sharp things and glue /disclaimer
Scorpio1
Post by Scorpio1 »
Wow that sounds scary, but effective!
Good idea though, as I'll be able to cut it to the exact length I need it.
I could always buy another one too, so I could cut one and have the other, JUST in case I do suffer loss of reception.
mole
Admin
Post by mole »
Yep I cut my down and didnt notice a loss in reception. I did make a post on it somewhere :roll: But try finding it!!!
Scorpio1
Post by Scorpio1 »
I couldn't find it, but I read that you get at it from underneath!!!
Oh no, I think I'll cut the garage instead! :lol: :lol:
Josh_PoloGTi
Site Admin
uhoh.... Don't cut your garage!
You need to twist the antenna off (it has a screw at the bottom of the antenna which goes into the black base that is attached to the roof)
You will see the base, then a fat bit of antenna, then a thin shaft, then a plastic cap (the top of the antenna)
Grab the fat bit of the antenna and unscrew it from the base.
It's so easy, there's nothing to it (why do you think it's so easy for kids to nick our antennas?) :evil:
Just unscrew the antenna, heat up the top plastic cap and remove it, cut the thin bit to the desired length, put the plastic cap back on, screw the antenna back on, look really happy :D
Scorpio1
Post by Scorpio1 »
Opps, I thought it meant to remove the aerial you have to undo the bolt under the headlining!
:oops:
mole
Admin
Post by mole »
Just to remove the base!
P8KSY
Post by P8KSY »
Scorpio1
Post by Scorpio1 »
I have used the Mini Bee Sting and the radio reception was VERY poor, the others look okay though.
Oh like the TDI badge, shame it's not the red one :(
Petrified
Sponsor
Post by Petrified »
Looking at this page
http://www.dubcessories.co.uk/gpa.shtml
do you think the Light Ring and Heater Switch Rings would fit the polo??
James.
Scorpio1
Post by Scorpio1 »
They're a different size aren't they? Not 100% though
