Mystery Fuel guage
Mystery Fuel guage
i was looking in my haynes and it says my fuel tank should hold 42 litres, whereas my car takes £10 to go from the redline to halfway, then another £10 to the top....surely that makes it about 25 litres? hopefully it is my guage and i can fit more in cause that extra 17 litres would come in handy if i do a long journey. not major but just curious
GroovyCarrot
- Sponsor
If it's anything like mine, the bottom of the red line will actually only be about 2/3 of your fuel.. there's a huge amount in reserve. The most I've put in my tank is £38, by which time I recon is was just about running on vapour. Takes strong nerves to run it off the fuel guage for that length of time though
you are right there!SteB wrote:Apparenlty its best not to let the tank run right down anyway - prevents rust and crap at the bottom entering the fuel filter
i would imagine the top of the fuel gauge isn't the actual top of the tank. i've put a fair amount in both my cars and only once has it touched the top of the gauge, and it stayed up there a while!
my old mk3 lied about how much fuel it had after a had to put a new tank in. there i was trundling to the petrol station just about in the reserve and she conked out! doh!
Gareth_GT_Hatch
- Platinum Member
Someone made a good point at work the other day about that theory:SpikeyG40 wrote:you are right there!SteB wrote:Apparenlty its best not to let the tank run right down anyway - prevents rust and crap at the bottom entering the fuel filter
If the fuel is always pumped out of the tank from the bottom, what difference does having an empty tank make?
Youve got to admit the guy has a point. Water (which is often the biggest contaminant) is more dense than petrol so it will lie on the bottom. Its probably worse if you dont do alot of miles (gives the fuel a long time to separate out)
We had this debate on clubpolo the other day, mk2 gauges are usually a bit mad, in that they only work for the middle half of the tanks capacity, and mk3 ones do indeed stay put until theres half a tank left and then the gauge falls really fast. I can live with the way the mk3 one works, its very accurate at the bottom of the gauge, and i guess it doesnt really matter if its full or as good as exactly how much fuel is in. the one on my derby stops working with 1/4 of a tank left. I left it for ages on the trip back from the polo show, finally decided to stop when it reached about 300 miles (which is good going as its only a 36 litre tank) and i still had a gallon or two left.
its a fair point! what you've also got to remember is that i suspect all the s**t moves around as the car moves and mixes with the petrol as it would be sloshing around in the tank.Gareth_GT_Hatch wrote: Someone made a good point at work the other day about that theory:
i think i've worked out my gauge's little quirks now and it's probably the worst quirk possible......i put £20 in the otherday when it was on the red and it did the petrol pump cut out thing meaning it was full...so that means i've got a guage which measures between 20-42 litres leaving me a 20 litre reserve which i'll need balls of steel to actually use???
