Performance Cams
Performance Cams
Does anyone know anything about performance cams such as where to get them what make and are they easy to fit for the Gti. Has anyone done this as well. Just cause my cambelt is due for replace and was thinking about getting uprated cams. Cheers
Well do be honest with you i read the whole post at the time and it ended in an argument so couldn't be assed searching for it again. I also wanted to know if anyone else had done this apart from you, i already knew you had done this mod and it sounded complicated. I only want to add some performance cams if there is any that i can just replace the standard ones with easily like in pug 106 gti's . My timing belt is needing changed soon so was just wanting to know if there was any kit out there.poussou wrote:Well...
If you had tried the "search" function of the forum you COULD have bumped onto my post about your question....AND ALOT MORE...
Try searching man....![]()
did u get a set of cams then??Jordan wrote:Well do be honest with you i read the whole post at the time and it ended in an argument so couldn't be assed searching for it again. I also wanted to know if anyone else had done this apart from you, i already knew you had done this mod and it sounded complicated. I only want to add some performance cams if there is any that i can just replace the standard ones with easily like in pug 106 gti's . My timing belt is needing changed soon so was just wanting to know if there was any kit out there.poussou wrote:Well...
i noticed on the post about winter wheels that u posted ur car spec and u have put cams on the list... wot kind did u get?
No i'm sorry but there are no "kits" out there.Jordan wrote:Well do be honest with you i read the whole post at the time and it ended in an argument so couldn't be assed searching for it again. I also wanted to know if anyone else had done this apart from you, i already knew you had done this mod and it sounded complicated. I only want to add some performance cams if there is any that i can just replace the standard ones with easily like in pug 106 gti's . My timing belt is needing changed soon so was just wanting to know if there was any kit out there.poussou wrote:Well...
I was one of VERY few that even tried messing around with this engine, and the results were really amazing, but i am no longer the owner of a Polo Gti.
I am now driving a shiny black MKV Golf Gti.....
Turbo is where its at......
No not yet thats future mods. Still thinking bout it tho.Grum wrote:did u get a set of cams then??Jordan wrote:Well do be honest with you i read the whole post at the time and it ended in an argument so couldn't be assed searching for it again. I also wanted to know if anyone else had done this apart from you, i already knew you had done this mod and it sounded complicated. I only want to add some performance cams if there is any that i can just replace the standard ones with easily like in pug 106 gti's . My timing belt is needing changed soon so was just wanting to know if there was any kit out there.poussou wrote:Well...
