ht lead question
182_blue
ht lead question
Post by 182_blue »
lol, another question, right got a bit of juddering when pulling away, not sure if its the clutch, but as a precaution i checked the ht leads, all of them appeared clean except one, which appeared to have a powdery substance in the connector to the ignition ?, any ideas, do i clean it, can i use wd40 to clean it out, is it knackered ?
moynas
Post by moynas »
Small wire brush on the connector ( I suggest a suede brush, gentle but very good) should do the trick if not you can buy connection grease which helps!!
