firstly raise the car safely (see safty in the how to section)
now you can cut the original backbox off but its a single piece system on my car so i took a disc cutter to it right next to the weld into the box
leaving me with this
note these pics are on a re instalation after i killed it with a kerb
then find some 2" diamater tube about 2 1/2' long and cut into it lengthways at one end (make 4 cuts one at 12'clock, one at 3o'clock one at 6o'clock and one at 9) i also added a chrome trim
then find a combination of clamps to clamp this new tube to the old system, you will also need to hold the other end up and i dont have a welder so i used wire (true ghetto stYle)
i will warn you though that this exaust is fairly loud (i can hear min when im really on the throttle, for about a mile) but the sound is very deep and throaty (not raspy) so you will prolly get a lot of compliments on the sound. hopefully josh will show up and tell you how he thinks it sounds.
btw remember that if youve just driven the car the exaust will be hot (duh!)
