After just 5.000 km, I got an indication to check the engine oil. The car apparently needed almost a litre of oil which I added. The dealer told me that this is normal for new engines, although I wonder if it is a bit TOO much for German engineering standards.
Is this common for new polos?
I' ve got the 16v model.
Oil consumption
des_pd_ tdi
Nelson_Wilbury
- Moderator
leonsmith
Oil use
VW included 1l of oil with my 1.9 TDi Sport - it even came in a nice faux leather case
The dealer said they'd started doing this because they'd had so many complaints from people that oil topups were needed so early on. This tells me that some oil useage is perfectly normal.
In my case, i've done 3,500 and it's still got plenty of oil, although I still check it regularly. I don't do any short runs so i'm guessing that helps.
