Norton Personal Firewall
des_pd_ tdi
Since the site logo and information have been added to the Polo forum first page I cannot access this site unless I switch off my Firewall, I obviously don't really want to do this - anyone else had the same problem?
des_pd_ tdi
I use the same Des and had bookmarked the main forum index so didn't notice the problem until you said.
I think the problem is the Ad blocking feature. The picture on the main page is called "banner.jpg" and I think the software then stops this from being displayed (thinking its an Ad). The way round this:
Goto Security Centre... Options... Personal Firewall....Then the web content tab... then under (Defaults) on the left hand side, goto the Ad Blocking tab on the right hand side... find /banner. and remove it. This should now work.
According to Norton help.... by permiting /banner. on www.tigerstyle.com it should overwrite the "deny" on the global list - it doesn't!!! I played with it for a good half hour and I can't get it to work like it should do.
If anyone knows anything more.... tell me!
Josh if you're reading, it might be a good idea to rename the image to something else that won't interfere with Norton. How many new members have come to uk-polos.net and not been able to get in!!!
des_pd_ tdi
At least I'm not the only one. I'll have another tinker later on when I get home and see what results I yield.
Maybe it's not just NPF users that have issues, don't want anyone not being able to access the site as when you hit this page it looks like the site is down
Maybe you should also have an email link on this page - should anyone encounter problems, then at least you'd know about it and they have a way of contacting someone. If I was not already a member and hit this problem I probably wouldn't bother persuing it and just move onto the next (inferior) Polo forum.
We don't want that to happen.
Des
Des
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
des_pd_ tdi
