Rear Wiper
tdisport
Rear Wiper
Post by tdisport »
My Rear washer has packed in..think the pipe has come away inside the boot as its all wet when i spray the water.
Any idea how to get the boot panel off, so i can pop the pipe back on?
Car well out of warranty so not paying dealer prices for small job!
Cheers,
tdisport
DAZZA_TDI
Post by DAZZA_TDI »
Hi m8 i had the same problem with the back window wiper washer not working but took off the panel and the pipe was connected :? came off elsewhere, the panel is connected with two or three screws then just pull it off the clips hope this helps
Dazza
tdisport
Panel
Post by tdisport »
Hi.
Sorry to sound thick, but tried to take the panel off, but couldn't find any screws or anything?
Could anyone help?
Thanx.
Gra-GT
Post by Gra-GT »
There is a screw in each of the grab handles on the inside of the boot. If you unscrew these then it should come off. You may need to jam a screwdriver or something down the sides to prise it off as the clips can be quite hard to unclip.
I had the same problem in mine over Christmas. Didnt realise untill we had a frost one morning and found I couldnt get in the boot cus I had soaked the lock and froze it.
Hope that helps 8)
