[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Whats the difference? - UK-POLOS.NET - THE VW Polo Forum
The ARC is the earlier ones, the AVY had changes made to it so it comformed to some new emission laws (euro 4), and you can also mess with the ECU with the port behind the ashtray on the AVY engines.
There may be other changes but non that I know of.
Yes but AVY engine u can do stuff to the ECU (i.e remap) where as ARC has siemens ECU where u need an actual chip to change stuff of that nature.
Yep, I understood what you meant, just hedgehogharvey referred to the port and I just wanted to mention that they all have it, what you can program or play with depends on the computer inside and the ECU brand as you said
hedgehogharvey wrote:
andyg wrote: you can also mess with the ECU with the port behind the ashtray on the AVY engines.
quote]
i have that in my ash tray,wondered what that was thanks
