[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 JACKING up a POLO - UK-POLOS.NET - THE VW Polo Forum
u can place the axel stands on the sills, polo's are light cars so it wudnt bend the sills in, but there shud b chassis legs 2 hold them on, im not sure tho
you put the axle stand in the same place you would jack the car up from and the sills for jacking and standing iver that or your could put an axle stand on the rear of the subframe.
Any 1 out there with a set of late VR6 calipers?
If you look on the sills, just under the doors, there are a set of downward facing triangles, one set behind the front wheels and one set in front of the rears, these are your jacking points.
