Spot the new subtle mod...
dino
Sponsor
Post by dino »
Can ya tell what it is yet -
If not scroll down a bit further
No - i haven't just been doing my hair!
quick how to - buy a new rear badge (or find a very nice Simon)
Separate them and spray the backing with plastic primer, colour and lacquer (or find a very nice Joe)
Stick em back together.
Heat the old badge up for a while (as shown above)
Get dental floss (any flavour will do) and using a sawing motion behind the badge to cut through the sticky foam pad.
What your left with will need removing - i did it with plenty of swearing, heating with a hair dryer and AutoGlym Intensive Tar Remover.
Till you get to this (took me bloody ages) -
Then whack your new sprayed badge on - stuck mine on with Servo Tape (available from all good model shops)
Big thanks to Simon for the badge and Joe for his spraying and warehouse use 8)
ModifiedMadness
Sponsor
Post by ModifiedMadness »
I spotted that straight away 8)
Looks great Dino, for such a small mod.
Couple of questions
1) Did you sand the black plastic at all
2) Is the spray out of a can or proper colour matched and from a proper spray gun, as I may consider this.
dino
Sponsor
Post by dino »
1) I think so - will check
2) Out of the spray can from VW.
8)
inder
Post by inder »
Spotted it too 8)
Nice pics and comments - great finish out of a can too!
dino
Sponsor
Post by dino »
Tom,
1) Yes it was sanded.
ModifiedMadness
Sponsor
dino wrote:1) I think so - will check
8)
Cheers Dino, do you buy the can from VW then?
dino
Sponsor
Post by dino »
Yep - ordered it from the parts dept. Came to around 11 quid which is for the paint and lacquer
DanDiesel
Sponsor
Post by DanDiesel »
that looks wickid dino!! such a small mod but it makes sucha difference to the rear of the car!!
i also notice u've got an s2000 aerial on there aswell!! :lol:
ModifiedMadness
Sponsor
Quality.
Last question which I forgot to ask last time :oops:
What did you sand it with? I'm going to spray my GTi badge black and Redline said to lightly sand it, but I don't know what with.
ICEYPOLO
Post by ICEYPOLO »
should be ok to just use wet and dry paper before primer, only need to key it a bit to get the primer somthing to stick to...
scott
Dinos-icenpaintman
Post by Dinos-icenpaintman »
Hi Joe here
Dinos badge was done without using primer! you can get a good key with the plastic that the badge is made out of.
Ive been painting with cans for a good few years now and dont really want to share my secrets sorry but buisness is buisness but it does involve several coats a flat sand more coats and several layers of laquer!
The VW paint cans are great they are a thin paint compared to halfords paint cans the laquer is good however can sometimes be a bit runny!
If you supply vw paint and laquer plus badge I can do the job for £20
May sound exspensive but consider its a good few hours of my time I think its worth it.
If you do want to do it yourself take your time and dont rush it!
mfa-polo
Post by mfa-polo »
Dinos-icenpaintman wrote:If you supply vw paint and laquer plus badge I can do the job for £20
May sound exspensive but consider its a good few hours of my time I think its worth it.!
How much for two badges?
Dinos-icenpaintman
same style badges? £30 if there both to be the same colour.
mfa-polo
Post by mfa-polo »
Both would be same colour.
I fancy getting a black badge sprayed up as well as a chrome, then choose which one to put on.
Should I contact Dino, when I get the badges?
dino
Sponsor
Post by dino »
When i pay you for the air filter you could stick the paint and badges in with it and i can drop it off to Joe for you?
