I have been doing a lot of shock shopping over the past week as my pretty little mk2 coupe has been bouncing around like zebidee.
My problem is I was looking to uprate my shocks without adjusting the ride height. I was wondering what everyone else uses. I have been in contact with g-max and found that there shocks can be used with the original springs.
Can anybody tell me if there are any other brands that I can use the standard springs with? I have been advised to go for spax or eibach but spax have discontinued there line of non-adjustable shocks.
After that I just have to do the tappets and i'm finished... Except for the bodywork and the paint and the tyres and the alternator and the wheel bearings, but after that i'm done.
1986 mk2 polocoupe 1.3 D Reg
Shocks without lowering
i think most people will always advise you to do shocks and springs together as the ride won't be as good with standard shocks and they'll wear out alot quicker but i think the official word is that you can use standard shocks up to a 40mm drop and then after that you definetly need uprated shocks. (although i'm with the above group
try www.venommotorsport.com they seem to do pretty good deals, for the extra £100 i'd personally just buy the whole kit to be safe.
Saint Jimi
I think you missunderstand, I would like to replace the shocks but leave the original springs in place as I do not want to lower this car.
All I want to know is:
Are G-max the only company that does non adjustable Shock absorbers that will fit on the car with Original manufacture Springs (exlcuding standard shocks)
Saint Jimi
