Looking at a GTi tomorrow, what to look for?
It's a Y-plate with 64k on the clock, 3dr in silver. Full VW history apparently, so cambelt should have been done by now?
I'm aware of the recall on the pedal box - is there a way to check if this has been done? Should there be any documentation with the car to say it's been done, any note in the service book etc?
So apart from that, any particular things to check over?
Thanks,
Steve
Thanks,
Steve
ModifiedMadness
- Sponsor
Keep the BBS
As far as the pedal box recall goes, there should be a stamp in the service book saying it was done, mine has. Ideally the cambelt should have been done, if not and it's from a garage see if they will do it for you.
And you mean the 6N2 is 4 stud the 6N is the MK4
Other than that it doesn't sound too bad
Well I've now moved upto provisional GTi owner
Put a deposit down on the one I saw this afternoon. The pedal box recall had been done and all the other paperwork was present and correct.
Does need the 60k service doing and the wheels refurbing. What would I be looking at for the service, inc cambelt, at a VW main dealer? And any decent recommendations for alloy refurb places, preferably in the North West?
Thanks,
Steve
Thanks,
Steve
congrats
Congrats on the purchase....shame it hadnt had its cambelt changed...looking at around 300 for the cambelt and then prob another 150 or so for the service as its a big one...maybe worth looking around rather than VW...a specialist...either way the cambelt change will require VW parts and so they sting you there...u want the tensioners and water pump done while they are changing the cambelt...better safe than sorry.
I have that joy awaiting me in 6k or so, so I've been looking around for prices.
I have asked my local mechanic on a cambelt change and he said it would be around the 200 mark...so i'll go local rather than VW...but if you can afford it then go VW.
Hope that helps.
Ohh and PS ring around a couple of VW maindealers and quote them each others prices...My last service was done at VW and I had prices at VW main dealers ranging from 79 to 180 pounds for the same service....needless to say I went for the 79 pound deal...that VW maindealer couldnt believe another maindealer was quoting 180...he even told his boss and said he'd report them to VW..because he said all main dealers SHOULD quote the same price.
Hope that helps.
Good news
Try these for split rims . You will save a bit if you split the wheels yourself. http://www.wheelrefurbishing.co.uk/contact.htm
Yeah, I would probably stick with a 15 if I were changing. With past experience, moving up sizes requires suspension changes as well to maintain a decent ride/handling balance - something I'd rather not do this time round....
Any brands, models you'd suggest? What do you run on yours? My decision really rests on finding a refurb company and happy with, and finding what they'll charge!
Steve
Steve
My suggestion is speak with Colin at Revolution in Newcastle (also in MaxPower & Revs Mag) He'll sort you out for the best deal and decent set. Excellent aftersales too! I run TSW Catalunyas on mine. They were a direct replacement and you can even use the old tyres off your corroding set! PM me for his contact number!Wardy wrote:Yeah, I would probably stick with a 15 if I were changing. With past experience, moving up sizes requires suspension changes as well to maintain a decent ride/handling balance - something I'd rather not do this time round....
Any brands, models you'd suggest? What do you run on yours? My decision really rests on finding a refurb company and happy with, and finding what they'll charge!![]()
Steve
