Part in the top of the engine
HK 6N2
Post by HK 6N2 »
Anyone know what is it inside the red circle?? :roll:
Grum
Post by Grum »
id say its the camshaft position sensor...
HK 6N2
Post by HK 6N2 »
Grum wrote:id say its the camshaft position sensor...
Does it relative to follow fault code by VGA-Com??? :roll:
17935 - Camshaft Timing Adj. Bank1 (N205): Short to Ground
P1527 - 35-00 - -
Grum
Post by Grum »
i cant say i know, iv never used a VAGcom or seen one used,
so i dont know if that code falls into having a fault with that cam sensor...?
HK 6N2
Post by HK 6N2 »
It doesn't matter :D
Thank you so much~
