VDUBGTI wrote:i have done mine but i am getting a white residue on the outer rim, any ideas how to remove it?
It's probably the effects of salt on the roads. Keep polishing! A light coat of WD40 or light oil will help to protect the outer rim when the weather is bad.
Looking good - well done! Just as a guide, how long do you rekon it would take me to refurb just the outer rims of all 4 alloys? My centres are ok but a couple of the outers are really bad and i fancy giving it a go.
owenjt wrote:Looking good - well done! Just as a guide, how long do you rekon it would take me to refurb just the outer rims of all 4 alloys? My centres are ok but a couple of the outers are really bad and i fancy giving it a go.
Id say i spent around an average of 2hours per rim. Its hard work though,id say i should have took a little longer on each rim. And all that rubbing down with the wet and dry did cause a few blisters
