polo power wrote:if your pedal box isnt broken and you have changed the cable, and its still stiff like mine was, its most prob your release bearing not sliding well on the shaft in the gearbox which is prob lacking grease, i replaced mine alone with a new clutch and its been fine ever since.
My clutch is heavy and creaks, I was thinking about replacing the cable, but it sounds like a common problem.
I have took off the kick panel and can see the whole pedal assembly, it looks fine to me, what am I looking for? Everyone seems to say ah yeah, the pedal box...... but does anyone actually know what the problem is, and what to look for? I see the cable coming in, and the cable attaching to the pedal. What can go wrong? From what people say it sounds like a weld fails and the pedal collapses, but you don't need a knew one, sort out a bearing for it.
I'm pretty certain that the heavy creakyness is down to the clutch release lever on the transmission. Anyone else had that?
