I've finally got my coilovers fitted on the polo, roughly 50-60mm down, and i think it looks so much better than standard, meaner, wider, and longer looking. (Also handles better!)
Here is a pic of it when i first got it home (the long way home) after fitting:
I think it has settled down a bit and dropped slightly lower now.
The guy who fitted it said the geometry on the car was very strange once fitted and it took them all day to get it right apparently, (only paid for the quoted amount tho), anybody know what would cause the geometry to be so bad?
From standard, it's a lot firmer, and there's hardly any body roll round corners, but it does seem a bit too "bouncy" at the moment, mainly on bumpy roads, so i think a bit of adjusting is needed. It's a bit scary sometimes when i go over a bump, or dip, as i'm pulling away, as it moves my accelerator foot, and i end up jerking away a bit out of control!
Does anyone who's had coilovers fitted know how i can reduce the bounceyness? (These are FK Konigsports). The only thing i can adjust is the damping or rebound i think, so i assume it must be that!
Sorry for the essay above,
More pics soon,
Ant
