http://www.spax.co.uk/downloads/KitsDam ... f/kits.pdf
Have you got a link to the thread recommending the kit, as I am also looking for a good 60/60 suspension kit (not coilovers).
Are you sure it wasn't the RSX kit i.e coilovers?
I do like the sound of the SPAX adjustable dampers, as they do not need to be removed from the car to be adjusted, unlike the Koni's (at the rear)as they are adjusted at the bottom of the damper, as opposed to at the top with the Koni's:
How do I adjust my rear telescopic dampers?
There is a knob or a screwdriver adjustment at the bottom of each damper. If you turn the adjuster fully anticlockwise it will be on the lowest setting, then turn the adjuster clockwise - On our newer dampers there will be 28 points of adjustment and on our older dampers 14. You need to count the clicks, as once the maximum damping has been reached, the adjuster will keep turning. Always adjust both dampers an equal number of clicks."
