dont think you can get one. i look everywhere for one
and a LSD, they only seem to do them for golfs.
you will have to change the gear box to get one.
i think!!
You have to rebuild the gearbox to fit an LSD in a front wheel drive car, as the diff is integral to to the gearbox.
Why you would ever want one on a FWD car doesn't make sense to me. If it's slipping, it's understeering, so applying more power really isn't the answer, better cornering technicque is.
An LSD makes a lot of sense if your running high power FWD to aid traction off the line as well as cornering. There's only so much you can do without one
i have 270bhp+ going thru my front wheels and it made alot of difference to my car
without my ATB diff it was under steer at every corner i put my foot down on
now with the ATB diff i can put my foot flat down thru a corner and it grips and pulls you thru as its putting the power to the wheel with the most grip = the outside wheel with most of the cars weight on it
any luck with this? i sent quafie an email this morning as im after one because hte main prob with the gti gearbox is the diff so if i can get one of these it could solve the prob!
kz, I am assuming from your signature you have a 9n3 gti? as opposed to a 6n2? Is that correct? If this is correct I would say you would be able to source one and it would be useful once you have fair amount of power to control.
