Electric Windows Problem
zahir_213
Post by zahir_213 »
Hi guys, I have a 6N2 Polo SDI with electric window problems and seeing as its basically going to be the same electrics for the GTI was wondering if I could get some help...
below is a topic I just posted on the MK5 section:
Basically when you try to operate the windows, through the switch or the even the key in the door(comfort module thingy) the driver side window just make a clicking noise and the glass will not budge. Its like the motor is stuck or jammed.
The switch is fine, thats been checked and replaced plenty of times. I have stripped the door down to try and 'spray some lube into the motor' as some people have mentioned before. This is actually impossibile to do, or am I just looking at it the wrong way?
I cant even get the motor out as the window has to be down in order to do it, and seeing as the window isnt working, not sure how im supposed to take the motor out?
I have checked the 12V feed going to the motor and this seems to be fine.
Im now all out of ideas, im not sure exactly how to take this mechanism out of the door having stipped it to the bare minimum. Anyone got any ideas?
Also I have got hold of VAG-COM and was just wondering if there is anyone I can do on there to work out what the problem is??
Its a bit of a strange problem, but I have a feeling its down to more than just the motor.
Anyone got any ideas what do with this electric windows problem before I go mad and just sell the damn car? To not have the use of a window in this heat is just a p*** take.
Any help would be appreciated guys,
cheers
