Door Bump Strips
Hayes-polo
Door Bump Strips
Post by Hayes-polo »
Do the bump strips on the doors of polo's have guide studs that fit into holes in the door or are they just stuck on with the foam strips? I wanna remove them from my other halfs car so it looks more colour coded. If I can get away with just removing them rather than painting them I will! Don't wanna go down the filling the door road. Any one done this?
jakethesnake
Post by jakethesnake »
Hi
On the mkIV or 6N they are simply stuck on.
On the mkV or 6N2 they are fixed through holes in the door plus adhesive.
If you have a mkIV simply heat the strips up with a heat gun or hairdryer and slowly pull them off.
Clean up the sticky mess left on the door and then give it a good wax.
Job done !. It looks miles better :D .
TONY
Post by TONY »
ive removed both the side strips and the rear badges. looks much better
look at the standardness! oh the horror!
LOW PHAT SPREAD
Post by LOW PHAT SPREAD »
When I removed mine, it left a mark in the laquer of the paint, n had to get both sides painted, which I was doing anyway so wasnt too bad.
henry01
Post by henry01 »
mine just pulled off then i used t-cut to remove any marks that they left.
looks mint now
