can anyone help?
ive posted on clubpolo but no reply..
my car stopped after a lot of hassle it turned out to be the igntion coil... but along the way to fixing, the car stopped priming the fuel pump and it wont start unless the fuel pump is manually connected... bought both the relays near the ecu and it still doesnt prime....or start unless manually connected...
i think its the ecu so am on the look out for one...
if anyone knows what part in the ecu that needs replacing (i think it is transistor 3) then please let me know so ill replace and test....
thank you for any help
